Formula? Boost vs HP gain??
Old Sep 30, 2006 | 11:12 AM
fastbasser's Avatar
Default Formula? Boost vs HP gain??
Is there such a formula?
Thanks
Old Sep 30, 2006 | 11:28 AM
anarchy99's Avatar
This might help assuming your air/fuel ratio is correct..
http://users.erols.com/srweiss/calchpb.htm
Old Sep 30, 2006 | 01:36 PM
engineermike's Avatar
We did alot of dyno testing on a 377 single turbo at everything from 3.5 to 18 psi boost. The power was remarkably close to NAhp*(14.7+boost)/14.7.
Mike
Old Sep 30, 2006 | 02:34 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Hmmm. Interesting link and calculator.
Old Oct 1, 2006 | 10:23 AM
fastbasser's Avatar
Thanks very much!!
Old Oct 1, 2006 | 11:18 AM
LS1Tech Co-Founder
I plugged in some stuff using 375 crank na hp for the engine parts and the results were anywhere from 930 to 1100 hp.
Old Oct 1, 2006 | 12:54 PM
nitrorocket's Avatar
I started with 450 N/A and it shows 1000 hp at about 18 psi. I put 430 rwhp to the wheels N/A with 11:1, now I have 8:1, I wonder how much power I lost? Should be close I think.
Old Oct 1, 2006 | 01:47 PM
fastbasser's Avatar
I punched in my numbers and the results were "about" what I expected. Guess proof will be on the dyno when all is said and done.
Yup,, you can just add boost to the formula and HP sky rockets!!
Old Oct 1, 2006 | 01:56 PM
yak's Avatar
yak
well, i know when we play with the vipers it's usally about 30rwhp per # of boost. this works out pretty good. I would think that the displacement would have something to do with that though so maybe 25rw/#?
Old Oct 1, 2006 | 07:31 PM
I've seen a pretty consistent 5% power gain/loss for every full point of compression change. So, dropping from 11 to 8, nets you a 15% loss. That's about 365 rwhp at 8/1.
Mike
Old Oct 2, 2006 | 01:13 PM
LS1Tech Co-Founder
I was figuring 400 crank hp for my longblock (at the most). Might be as low as 375 crank hp but I'm thinking 350rwhp.
