sts dealers question or custom rear turbo owners
is it possible to buy the hot parts and intake only. i have my turbo already and just need the tube running to the intake and hot parts. Also, if anyone has made there own rear turbo setup. what did you use for the piping from the turbo to the throttlebody? stainless?
STS won't sell you anything individually unless your a customer.
If your doing a rear mount, you'll just use your stock exhaust. Then just buy some U's and straight sections of HPC coated pipe (summit or ebay) and have a local exhaust shop do the bending. Then buy the silicone couplers and some brackets that will bolt where subframe connectors go. Weld those to the intake piping. Plain rectangular brackets work good just drill the proper size holes.
You said you have the turbo. What are you using for a pump, lines, vacuum, pcv, check valves? I'm building a custom setup as well, do you have any pics of yours?
if you don't already have a pump, there's a lot of guys using a mocal diff cooling pump. Its avail at racerwholeparts.com (I think that's the site). Just search and you'll find it
hey we need to talk more
im just starting and i found my turbo is too small, im going to go with a t 70, the oiling im still trying to figure out. i wish sts would sell parts separate, kinda of a rip for what you get i think
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
what turbo did you originally have? A 60/67 is pretty decent for stock cubes. You can basically duplicate sts setup with that pump for the oil. Just wire into accessories to turn on and mount it near rear axle where sts does. tap the filter piece for the feed line and you can use the oil cap for the return line. Just run the line next to your brake lines up to the engine bay and drill a fitting into the cap.
Then use a check valve to prevent extra oil and one near the turbo to prevent oil from pooling in while the car is off (if you havent already done so). PM me if you want more details ill see what i can do, ive only done so much on my setup so most of what i know is just in writing/parts. GL
the piping is just HPC coated aluminum. Stainless can be used. Just make sure its not galvanized and coating is good to keep temps down. You want it to be as cold as possible. The sts kits come with 2 1/4 size pipes up to the maf.
i would go with some LQ9 heads to lower compression. Your fine without a forged bottom if your running relatively low boost. What kind of numbers are you lookin for? you can be safe with 8-9psi and an IC and be making around 550rwhp. just keep the tune fat. if you have bigger future plans i would tear it down.
Looks like you guys have it all figured out. Just a word to the wise, you already mentioned it but deffinately get the restrictor going into the turbo and stay away from the Tilton rear end oil pumps. They are LOUD, I can speak from experience.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Wolfee
Wolfee
If I did another custom setup on a truck it would be a front mount. It be the same amount of work with better results IMHO
Originally Posted by MNC5
I did my own custom on a Silverado. I used Aluminum piping.
aluminum pipiing is ok to use?
I would not coat the aluminum. It will not rust and will dissapate the heat very well.
STS uses mild steel that is coated with a non thermal coating, not regular old
ceramic coating.
ceramic coating.
I use the aluminum when I can. We did a custom rear kit on a Blazer and everywhere I could I used aluminum and if the pipe was going to be close to any heat or other metal that could damage it I used stainless.
With the aluminum, the IAT's were better than using steel.
