LQ4 or LQ9
Old Mar 3, 2006 | 09:32 PM
B_Thompson's Avatar
Default LQ4 or LQ9
Which block would be better for a turbo setup. I have found several of both at some salvage yards in my area. Well if both motors are almost the same then it shouldn't really matter but I just wanted some other opinons from people that have built turbo motors before. Thanks for the help.
Old Mar 4, 2006 | 05:40 AM
smokinHawk's Avatar
i think the only thing different is the pistons, with a different compression height. so if your putting good internals eith one will do the same job.
Old Mar 6, 2006 | 09:47 PM
B_Thompson's Avatar
Thanks for your help man..
Old Jan 11, 2007 | 09:57 AM
B18CYA's Avatar
is this true?
I want to use my 98 heads will either block work?
Old Jan 11, 2007 | 11:12 AM
Firechikn's Avatar
Same block on both engines, just different pistons, cam, heads. Tell them you'll take the sorry low compression LQ4 for a discount. hehe
Old Jan 11, 2007 | 11:26 AM
98turbls1's Avatar
Originally Posted by B18CYA
is this true?
Why would you want to use 98 heads?? 98 heads are the worst design of the LSX era... I would go with some later LS1 heads or maybe some worked Lq9 heads if you want to run FI.... Just my opinion...
Old Jan 11, 2007 | 11:41 AM
B18CYA's Avatar
my ported 98 castings made 400rwhp on my 346 A4, not going to find a factory casting for free that flow like they do. Plus got 918 springs and ferra valves in em.
Old Jan 11, 2007 | 11:54 AM
Rickys S/C Z28's Avatar
cool beans!!!
