spark plug indexing
Old Mar 7, 2006 | 03:57 PM
Mr_president's Avatar
Default spark plug indexing
witch way is the best way to index my tr6 spark plugs on my 6 liter stock heads with the turbo set up
thanks!!
Old Mar 7, 2006 | 04:03 PM
GrahamHill's Avatar
Should you really need to?
Old Mar 7, 2006 | 05:24 PM
no put i heard you gain 22% hp
Old Mar 7, 2006 | 05:32 PM
stevieturbo's Avatar
If only that were true....
Old Mar 7, 2006 | 06:47 PM
DeltaT's Avatar
I'd be happy with a 2.2% gain... No way they're worth 22%.
If you want to do it, I just use a Sharpie to mark the electrode position, and a set of Moroso Indexing Washers - they come in 3 different thicknesses that allow you to move the electrode position in approximately 60 degree increments.
Jim
Old Mar 7, 2006 | 09:35 PM
thanks in witch direction would you have them pointing and at what time like 10 and 12 or what ever it is?
Old Mar 8, 2006 | 12:08 AM
DeltaT's Avatar
I always was taught to point the gap as close as you could to the center of the exhaust valve.
If you are careful, you can use those Moroso washers a number of times.
I index the plugs in all my motors. Every little bit helps.
Jim
Old Mar 8, 2006 | 09:11 AM
618HAWK's Avatar
Jim
I am not questioning you but why to the C/L of the exhaust valve and not toward the intake.
Would it be for issues of the f-a mixture hitting the plug from the side vs the front????
Old Mar 8, 2006 | 10:50 AM
GrahamHill's Avatar
We always indexed to miss the piston, lol.
Outside of that id just put 'em at 12.
Old Mar 8, 2006 | 02:24 PM
DeltaT's Avatar
I think it's just a target point to ensure the gap is open toward the chamber.
Jim
