Do I need Alky/Meth injection?
Old Mar 14, 2006 | 06:13 PM
Junior's Avatar
Default Do I need Alky/Meth injection?
I will be running a stock short block with some MTI 5.3 heads, D1SC pullied for 7-10 psi. Speed inc. sc1 blower cam and headers. Do you guys think i shoud get alky injection? If yes which one do you guys think is the best one? I really appreciate your replies, THANKS.
Old Mar 14, 2006 | 08:09 PM
2002 Trans Am's Avatar
It wouldn't hurt....A lot of people seem to use the Snow kit as well as the Alkycontrol kit
Old Mar 14, 2006 | 08:15 PM
Assassin's Avatar
with 5.3 heads on a stock bottom end and 7-10psi I would say ummm..... YES, throw a thicker head gasket on there too...
white_camaro's Avatar
i dont have a suggestion for your question but its always sad to read a sig that has r.i.p. written about a fallen f-body. it seems as if you really liked your old setup because you did the same mods on your new t/a.
Old Mar 14, 2006 | 08:42 PM
peter pan's Avatar
Thumbs up
Get the alky and get the ECS kit as Juilo really supports this system to make sure it works with your setup
Old Mar 14, 2006 | 08:44 PM
mdhmi's Avatar
What type of pump fuel do you have available locally? Are you willing to run 100 unleaded? That would be my first choice, if not I'd contact Julio at Alky Control.
Good luck,
Mark
Old Mar 14, 2006 | 08:47 PM
Junior's Avatar
Whats the ECS kit? Kinda new to this alcohol/meth stuff THANKS
Old Mar 14, 2006 | 08:53 PM
peter pan's Avatar
Goto the ECS website or call Doug or Chris they will hook you up with this kit, I love the setup and I use it for protection more than for power with my setup
http://www.eastcoastsupercharging.com/
609 752 0321
This kit helps to make sure I have enough fuel when I take my boost in excess of 10 lbs as I like to do on the open road, a little safety in my book goes along way with FI setups. When I hit 3 lbs of boost the meth starts spraying to make sure I have extra fuel to burn and not go lean.
Old Mar 14, 2006 | 09:14 PM
mdhmi's Avatar
The ECS kit is the C5 version of the Alky Cntrl kit.
Mark
Old Mar 15, 2006 | 12:27 AM
89Formulaws6's Avatar
you can make your own kit if you wanted to, you can use winshieldwasher fluid as well
just an idea.
definitly worth it
Old Mar 15, 2006 | 12:31 AM
solobaric's Avatar
Might consider selling your 5.3 heads and picking up some 6.0 heads instead of using that money on a meth kit. Would help lower compression at least. Good luck!
