front mount turbo v.s. rear mount turbo
Originally Posted by Frost
From your own admission the cam was optimized.... for the SC... for a more realistic set of representative numbers why not cam each accordingly?
Having built my first turbocharged car in 1985, I had some real doubts when I first heard about the STS kits last spring. I had decided to buy a GTO after the ford dealers were price gouging on the new mustangs, and KNEW I'd be looking for more HP for the Goat.
Started reading on LS1GTO.com about the STS cars. Read over here. Put on my thinking cap. Looked at the issue of underhood heat on the goats. Tried to contact Jose but didn't hear back [STS probably had W & the feds intercept that email] as I live in Birmingham. Didn't want a procharger because I wanted better midrange power. And Kenne Bell clearly wasn't going to step up to the plate.
So, I had some emails w/ STS, and they agreed to work with me to do the first LS2 with a rear-mount system. They have been very responsive as I was discovering the differences in the '05 vs. '04 exhaust, maf, throttle body, etc.
Thoughts: the system is a compromise, as virtually EVERYTHING in life involves a compromise. The length of the exhaust pipe before the turbo [and the cooling it experiences] will naturally slow down the response time of the turbo. A smaller A/R helps. The lag is most noticeable is when you first get into it as there is a slight bit of hesitation...but NOTHING like my wife's WRX, as a comparison! And once it is spooled and the plumbing is hot, the return to boost is instanteous on shifts [M6 tranny]. Some here have removed cats and found quicker spool, and we have discussed whether or not that a heat wrap would help.
The plus side is that the intake charge is MUCH cooler than a comparable front mount system, and if you look at the actual volume of the intake piping, it is a negligible amount [calculate how many cubic feet live in that pipe, and divide that into cfm...very small amount of time!]. The underhood heat is no problem in this car. The intake air is cool. Much easier installation.
And is sounds scary when you blast by someone!!!
Perfect? No. But I find it to be an effective compromise and a great addition to a TRUE daily driver car [in rush hour traffic and whatever else], especially in a car that is really a high end 'gran touring' car [as opposed to a muscle car].
Front mount...love 'em. I am seriously considering a more traditional setup on a 65 Mustang fastback I have sitting in the garage, and will likely talk to Jose about that car...adapt some PTK plumbing to fit the available space? That car will be set up with a full cage and road course suspension for open tracking...with a few runs at the strip at some point.
The automatic-equpped STS goats have certainly shredded some 1/4's...build that boost [brakes vs torque converter], get enough sticky rubber and proper suspension to hook up, and blast off!
BTW: in a severely traction limited first trip to the 1/4, car went 12.3/119 @ 7psi. VERY hard to get it rolling due to track conditions...and actually, more instant boost would have likely made launch even harder! This car was never designed to be a drag car [M6; suspension more of a "handling" setup; and 19" wheels won't provide the necessary traction, especially w/ IRS in a 3900# car (including a very nice custom sound system and sound deadening= MORE weight)]. Out on the open road, the car is a joy to behold.
Originally Posted by JZ 97 SS 1500
Umm, I will stay quiet as long as possible on this one.
engineermike, I love that we did the test long ago. Hell we had a front mount and everything before they we ever made for the STS's...lol. The HP gap was as much as 100rwhp at 14psi and lag was ~500-1000rpms worse. We have all the data somewhere in our archives. Its was nice to bolt the STS system on, run it 3 times on the dyno, then unbolt and bolt in a front mount kit and see the actual differences with the same turbo used on both. Never bothered posting it.....would have started a full out flame war...but we know first hand what is BS and what isn't.
. We still do alot of work for the rear mount turbo guys and help improve on turbos they have. Their is much to be desired on the units used and we welcome anyone who wants to go faster, whether front or rear mount.
*** Disclaimer****Picture attached is just a joke guys...... It was sent to us by a friend of ours.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Oh an heres your kit in all its might 8psi and 420hp...by 4k, not exactly blowing anyones skirt up, but im sure you have an excuse...theres lot of sts cars making 500rwhp by 4k...but we know...they suck blah blah blah. I mean I dont even have one anymore...why bother right
Originally Posted by nossty1
Alright guys, I am having somewhat of a problem with how much boost the car is running. First of all my mods are in my sig. The car is making 420 rwhp 440 rwtq at 4000 rpms, that is when they shut it down. I have the t70 set for seven psi, but they are telling me that it is making 8 psi at 3500rpms. They are worried that the cylinder pressure is going to be to high. They say I have a couple of options, stock cam, stall coneverter, or lower the boost with a 4lb spring. I guess the car is running out of fuel or something. Maybe you guys could shed some light on what I should do. BTW stock shortblock and heads. Sorry if I dont know what I am talking about I am new to FI. ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
LS1TECH Sponsor
Originally Posted by PurEvl
jose dont be mad because carteks sts version on there vette went 9.3 and proven on video...its ok a rear mount is faster then almost all your cars...although the hear say about you systems is exceptional...I would sooner expect a video of space people then a ptk kit at the track or a dyno at your shop.
And shave your ***
BTW, I thought that picture was you holding the kit to your mouth....
Also the kit mentioned above is having tuning problems...not the kits fault. We both know which setup makes more power.....if it didn't why isn't that T88 of yours hanging from the rear
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I think the old cliche is (Practice what you preach)....
As always broh, great fun posting with you.....
Jose
LS1TECH Sponsor
Oh and one last tidbit..... Here is one of my customers and good pal....in....
OH NO, whats this..............
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
http://www.nick.neptune.com
Look out the window...you might see some green people walking around
blah blah blah...woulda shoulda coulda but hasnt...and if the 88 would fit i would hang it back there just to **** you off. And the kit above is not having tuning problems, its having OVER boost problems and its still making mediocre power. So you guys must be living the high life with YOUR one proven kit. Sts is lauighing all the way to the bank blowose
LS1TECH Sponsor
LS1TECH Sponsor
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Rear mounted vs Under hood mounted turbocharger - I really would like to see to cars running similar boost with similar mods go at it. I have the STS kit on my camaro and it pulls very strong. I already beat supercharged cobras already just on 5psi on the street. These kit's are no joke they make serious power and torque. I would really like to race one heads up to see the difference
#34
I don't have any regrets. ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I'm majoring in physiology with a minor in physics, & I'm perfectly aware of the arguments against the STS kit. As far as optimization is concerned, a front mount kit is better - but there are other benefits to a remote mount that have been largely ignored. The STS kit isn't inaffective by any means, although it certainly isn't there for guys who want 7 second runs. I said it in another thread: it's about what kind of results you're looking for. I got my kit for under 3 K & I got the works (bov, ebc, methanol, turbo upgrade) for under 4K for everything total & a relatively simple install. I'm hoping for nearly 700 ft lbs. with a near maxed application.
I'm not a speed addict, I'm a car enthusiast. I don't want to be so fast that I cook engine components. My goal is and was 10 seconds. This is perfectly reasonable given my setup (and considering I have an LT1). I'm not working to be the fastest guy at the track.
On a secondary note, whoever said that the STS kit is 'not done right' has little regard for engineering ingenuity. It's a two pronged insult: first of all, any issues with the system stem from a conceited value judgment concerning what a turbo system SHOULD BE. This is pompous nonsense - tell me, exactly, how an STS fails to do what it's supposed to do? These kits make damn fine power. Secondly such statements don't take into account the financial restraints many of us (like college students working toward grad school) have to live within as well as the goals they have.
In any case, I don't think my 2 bolt short block is gonna be handling much more than the power level I'll be at with STS, so I'm right at where I want to be.
#35
Ok, Ok... I will admit I am only running 607RWHP with my STS on a stock block... A front mount is more efficent by design. But I can do one thing that 90% of front mounters cant... I drive my TA for 2 hours down to the track.. jamming to my music with my AC on the whole way... I race... beat most... then drive back again doing the same. This summer when I go with the new setup.... I plan to do the exact same but with an 850+RWHP STS setup... run 9's and still enjoy my AC on the way home.
#37
#38
Originally Posted by detroit_903
. . . I really would like to see to cars running similar boost with similar mods go at it. . . .
And, yes, there are fast STS cars out there. There are also fast Civic's, fast cars with stock heads, fast cars with stock cams. . . that doesn't mean that it's the best way to do it.
A car can be fast because of a component, or in spite of it.
#39
![Thatfunny](https://ls1tech.com/forums/images/smilies2/thatfunny.gif)
Ok question for the folks other then the cheerleaders...
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
JZ, Pure, anyone else with an educated opinion will be appreciated not trying to jack the thread.. I think it is relevent:
The right turbo for a 408 App being used in an STS setup. What would be the ideal A/R and turbo size. Could an STS not compensate for the later spool and smaller A/R with a larger turbo? I am sure that there are some limits to space... but in your opinion what is the most efficent turbo with the nessessary A/R for a 408 Cube motor? You laugh about hanging an 88 from the rear, but what are the real limits?
Thanks gents... trying to learn here... I am a realist and I understand the advantages of a front mount. I choose to use a rear mount STS... now I would like help maxing it out and seeing the 9's.
#40
...in order to add more validity and worth to the numbers coming from your 'experiment'.
Why would I go through all this trouble when my turbo made more power than my supercharger even with the supercharger cam??? Then again, I didn't optimize the supercharger cam either. Oh crap, guess I gotta put the T-trim back on there and try a few cams with it first. . . What's the point? I got 30 hp more with a turbo over a supercharger so my point is proven.
Mike
