First Track Day For The Turbo Formy
Old Mar 19, 2006 | 07:11 PM
frcefed98's Avatar
Originally Posted by KAOS
what was your 1/4?
Uh .5 slower(13.0@110mph) with the car hitting the limiter on the 1-2 and 2-3.....had to let off the gas to get the car to shift both times.
Wasn't slamming you just comparing 1/8th mi times there big guy
Good luck hope you didn't tear anything up.
Old Mar 19, 2006 | 07:23 PM
Jammer's Avatar
so you all think its something simple then. i guess beating the **** out of it one night then taking it to the track didnt fare to well. oh well im happy with the 1/8 mph. wonder what it would have been in the 1/4 if it would have held
127 in the 1/4 woulda been good.
Old Mar 19, 2006 | 07:27 PM
kp's Avatar
kp
That kinda sucks after doing so well on the dyno. If its not blowing smoke out the oil fill cap like a freight train its probably nothing serious.
Old Mar 19, 2006 | 08:29 PM
black98ws6ta's Avatar
My car with almost stock weight and a 6 spd on et streets went 103 and 131 at 570 rwhp and 640 torque. I would expect 2 mph or so for you. It will have crankcase pressure if the tick is in the bottom end(ringland).
Old Mar 20, 2006 | 01:56 AM
KAOS's Avatar
no no buttercup. if you remeber i said that my goal was to beat your timein the 1/4. so my goal for the year is accomplished, lol. meant nothing by it. going to check it out on monday. hope to have it on the road again soon
Old Mar 20, 2006 | 01:57 AM
KAOS's Avatar
not coming out like a freight train but it was having some blow by. but i havent put that check valve in yet
Old Mar 20, 2006 | 11:42 AM
KAOS's Avatar
well... all springs and push rods look good. any more suggestions
Old Mar 20, 2006 | 12:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You didn't spin a rod bearing right? Do you know what that sounds like?
Old Mar 20, 2006 | 12:13 PM
LTLHOMER's Avatar
I feel your pain about doing well on dyno and then running like crap at the track...who tuned your car?
Old Mar 20, 2006 | 01:42 PM
Boostaholic's Avatar
Well ****, I told you not to blow it up!
Old Mar 20, 2006 | 01:44 PM
WestSide's Avatar
Where do you think the tick is coming from? Top of the motor?
Old Mar 20, 2006 | 02:15 PM
  #32
KAOS's Avatar
PSJ.. i do not know what a rod bearing sounds like.
westside it sounds like the tick is coming from the top of the motor
ltlhomer.. it ran good something tore up. i dont think tune had anything to do with it.
bought an fn compression tester but not sure if that will tell me anything or not. those things are a joke. any body ever have any issues with the lifters?
Old Mar 20, 2006 | 02:39 PM
  #33
LTLHOMER's Avatar
I was just wondering not saying it had anything to do with the performance...sorry if it seemed otherwise.
Old Mar 20, 2006 | 02:43 PM
  #34
LS1Tech Co-Founder
Did you check the oil and make sure it does not have a lot of shavings in it?
Ticking can be a lot of things, like a bolt backed out of a flexplate, or a spark plug with a cracked ceramic.
You have to check stuff.
If your oil pressure warm is up and down, it could be a rod bearing.
Old Mar 20, 2006 | 02:47 PM
  #35
CHRISPY's Avatar
Maybe a lifter problem? Are you getting any slop on the pushrod?
Old Mar 20, 2006 | 03:58 PM
  #36
Scalpel's Avatar
Broken ringland, lifter stuck, rocker arm bearings gone.
A bearing going out would have a metallic knock/thud that usually increases with RPM.
Old Mar 20, 2006 | 04:41 PM
  #37
2000 ws6's Avatar
The airfuel was 10.9-11.0 when tuned and 18 degrees of peak timing. We kept the a/f and timing safe. Had 0 KR when tuned.
Old Mar 20, 2006 | 04:44 PM
  #38
rod442's Avatar
can you tell whether the noise is consistant with crank rpm? or is it more like 1/2 engine speed? if its half engine speed its in the valvetrain, crank speed its in the motor.
I have a noise in my motor that is currently scheduled for replacement. naver had any shavings in the oil, or copper stuff or anything.
I suspect my noise is a bad wrist pin. replaced the lifters, replaced the rockers, pushrods were fine, changed to 6.0l heads. new clutch. if you get it torn all the way down (heads off), and dont find anything, thats what my money is on.
be a couple of months before I finally figure out what my noise was still. BUT Ive been driving it with the noise for 6,000 miles, and racing it 3-4 times a year for the last 2 years with the noise. lol. it hasn't come unglued yet, and makes as much power as always.
not saying you should do that, but I was gonna run mine till it blew up. now that I can change the short block in my car, Im going to.
Old Mar 20, 2006 | 05:13 PM
  #39
KAOS's Avatar
well i did a compression test, could NOT get to the back plug on the passenger side, it spand anywhere from 190-120. 190 sounds high to me but i checked it twice. all rocker arms are moving when the motor is being turned over. and yes the more it revs the faster the knocking sounds. and as far as oil pressure goes when warm it has always fluctuated more after i tapped in above the filter. had to quit for the night was getting ready to set it on fire
Old Mar 20, 2006 | 06:08 PM
  #40
Scalpel's Avatar
190 to 120? Did you let it crank about 4-5 times before taking the final reading?
They should all be within 8-10% of each other, a little less would be ideal, and the lowest reading should be no less than 10% of the highest # seen.
