Post pics of 4" down pipes
Old Mar 20, 2006 | 08:59 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Post pics of 4" down pipes
Where are you guys putting the 4" down pipes if you are running truck manifolds? Please post pics
Old Mar 20, 2006 | 09:13 AM
smokinHawk's Avatar
Well since im about the only one with a 4" downpipe (using truck manafolds anyways, na$ty-ta has one-no truck manafolds though, and mike is using a custom motor mount and a 5" pornstar-pipe.)
Attached Thumbnails Post pics of 4" down pipes-dp-wg.jpg   Post pics of 4" down pipes-dp-y2.jpg   Post pics of 4" down pipes-dp-y.jpg   Post pics of 4" down pipes-fatdownpipe1.jpg   Post pics of 4" down pipes-fatdownpipe1sml.jpg
Old Mar 20, 2006 | 09:17 AM
smokinHawk's Avatar
another
Attached Thumbnails Post pics of 4" down pipes-fatdownpipe2.jpg   Post pics of 4" down pipes-hotpiping_side.jpg   Post pics of 4" down pipes-hotpiping_top.jpg   Post pics of 4" down pipes-turbo-dp2.jpg   Post pics of 4" down pipes-turbo-dp.jpg
smokinHawk's Avatar
motor mount trimming (actually trimed more then shown here)
Old Mar 20, 2006 | 09:40 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Good pics, I was wondering if it would fit thru that location. Is that a BMR K-member?
With the turbo that low, were you going to still be able to use a gravity oil return line?
Old Mar 20, 2006 | 09:48 AM
SINISTER's Avatar
it will fit with a lilttle messaging of the k member
Old Mar 20, 2006 | 09:50 AM
smokinHawk's Avatar
yes bmr kmember.
the turbo is above the oil pan level so using a gravity drain, its about the same level as the TTi race kit is. I wanted to go higher but my water pump was limiting me
Old Mar 20, 2006 | 09:54 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Thats why this site rocks, instant pics of someone else's combo. I was planning on putting my turbo there, but its good to see pics of one that is already installed. That takes a lot of the guesswork out.
Old Mar 20, 2006 | 10:51 AM
smokinHawk's Avatar
it almost seems like the downpipe was made from GM to go their.
as thats the side the exhaust runs on after the ypipe and you will have the most clearance that way instead of trying to get it to pass over the tranny.
ill have to get pics soon of my whole 4" exhaust that goes to about my rear tire, looks like its from a diesel truck or something.
are you keeping your PT88 or getting a differnt turbo?
you planning on mounting it straight on (i did mine like that so it could get air from the passenger fog light) or sideways so you can keep a full length radiator?
Old Mar 20, 2006 | 12:22 PM
NA$TY-TA's Avatar
The way they did mine Tony it would of never fit with the BMR....
Thats why we went with the AJE K-Member....
Here's mine ...
Kyle
Old Mar 20, 2006 | 01:13 PM
Nine Ball's Avatar
LS1Tech Co-Founder
keeping the PT88 for now. If running 8s gets boring I think I'll just get into sky diving
Haven't decided 100% on turbo placement, just wanted to be sure the d-pipe would fit in that location with truck manifolds.
Old Mar 20, 2006 | 01:19 PM
mahhddgtp's Avatar
You have some cool toys 9ball. Keep us posted
Old Mar 20, 2006 | 01:45 PM
Navy David SS's Avatar
Lets see if this works for you. Joey's 98 SS, T-88, 5", truck manifold. Will not fit through stock K-member, but he is buy one - from a non-spouse (Anthony Jones Engineering), that will allow it to fit perfect.
Attached Thumbnails Post pics of 4" down pipes-joey1.jpg   Post pics of 4" down pipes-t884.jpg
Old Mar 20, 2006 | 01:56 PM
NA$TY-TA's Avatar
Same one im Using... AJE......
Kyle
Old Mar 20, 2006 | 03:01 PM
Nine Ball's Avatar
LS1Tech Co-Founder
dang that 5" DP looks huge. Maybe we should make them stick up thru the hood like diesel stacks
Old Mar 20, 2006 | 03:18 PM
SINISTER's Avatar
Kyle
you guys useing power steering or manual rack?
Old Mar 20, 2006 | 03:54 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Madman manual rack on my car.
Old Mar 20, 2006 | 04:26 PM
NA$TY-TA's Avatar
I still have power steering..... manual brakes though.....
Old Mar 20, 2006 | 04:52 PM
Brandon Boomhauer's Avatar
what does the AJE help with? just its design allows more room, or what?
Old Mar 20, 2006 | 06:33 PM
PurEvl's Avatar
fyi even with lots of custom work the 3 1/2 pipe bangs here an there, we have had to adjust it to get it right. 4 will be tight no doubt
