WILL THIS REAR MOUNT work???
my question is will this work at lets say 5-8psi (to be conservative) and what numbers(times/rwhp?) should i get more or less? i will be upgrading heads/cam/valvetrain in the somewhat near future so....
REAR mount turbo setup is as follows:
*master power turbo, compessor side is .70..exhaust side is .81
*tial 38mm wastegate(spring setup for 4.3psi right now)
*greddy type-s bov
*braided oil lines for feed/return
*mocal diff/oil pump for the return to my oil pan
*check valve for feed line so oil wont pool in the turbo when engine is off
*fuel pump already replaced, stock replacement walbro 255(racetronix)
*custom piping/filter/and shield for weather..and 2 1/4" piping for the intake charge
*for sure 42 lbs injectors if i go change the 4.3psi spring for something bigger
* and yes i know TUNING is the most important thing overall...
** im sure im missing something else but for now these are the major components...
ok give me ur thoughts, concerns, ideas, anything and everything to help me make up my mind
I'll be honest, the kit will work, but if your just gonna be looking for 100 Hp I think you should consider finding a used STS.. why? The wiring harness makes life easy, as does the quality oil pump / built ilow pressure alarm etc.
However, sounds like you have the ability an knowledge, I bet you can make it work.,.. and best of all, you did it. So I say go for it if you have some fab ability and let me know if I can help at all.
Reliability ends if the oil system fails..remember that.
You will make more than 50 HP.
Are you intercooled? Prob not...thats ok for low boost. 11's may be hard with what your working with. Cant expect a great 60 foot and that hurts the 1320.
**and yes i do wanna run an intercooler behind the front license plate where the bird is...i jus wanna get it on and running first on the 4psi the wastegate came with...and then put on the intercooler when i up the boost, upgrade injectors, etc etc
**ok lets say i dont run the dual speed system/hi-low for the return oil pump, i jus run the pump with a relay so it can turn on and off with the ignition, that would work too wouldnt it?..i know the 2 speed hi low deal would be ideal but i duno how easy and cheap that switch would be to get, or how necessary it is overall....and yea i know u told me oil is the life of the system..but dam lol
Running a 13.30 @ 106.xx, you should be at least 115+ if that's what you're worried about, and like others have said, with that ET, your 60' times aren't the best, so get a good set of drag radials like the MT ET street radials, and a stall higher than stock (our cars are heavy, and higher rpm + load = boost) to get the turbo spooled up. You should be fine, just don't beat on it with those stock injectors, trust me... Let me know if I can help you with anything.
the only big question i have is about the oil pump/system...all these pple talkin about running it with a switch for high/low speeds like the STS...and the pcv system what the hell do i do with that? what do i have to modify to boost the car?
