incons meth methanol alky tests
Here are my results.....all stuff done at 16.5-17.5 psi
My intercoolers are maxed.....starting line IAT 90 deg.....finish IAT 189
No intercoolers..start 90 finish 240
I have never measured AFTER the meth to see how much it helps. Today i did a few pulls on the highway. I used a Fluke thermometer/meter with the sensor in the throat of the intake where the pcv nipple is...it was slid in enuff to be right in the airstream and the meter on my windshield so i could see it. I watched IAT on my hptuners...the factory sensor is in the buttpipe. The factory sensor/fluke measurements were within 3-5 degrees of each other driving around today (no intercoolers). Got on the highway...IAT started at 95...rising to 183. Temp measurement after methanol was 82-83 degrees on both pulls. Thats a 100 degree drop!!! I was quite shocked. This is Meth at 75 psi...m10 and m15 nozzle. Soon I will try meth/water 50/50 and after that more pressure with my shurflow pump. Oh, the intercoolers weigh about 10# each...replaced with a little bypass pipe so i'd say removing them nets you an 18# weight loss
And also are you using a programmable controller or just a regular hobbs switch? Your results will probably open some eyes on methanol injection. It's definitely worth trouble(watching tank levels) in my book. Good luck.
Oh...i got the nozzle sizes from the buick crowd...over 600hp and they use 2 nozzles
Damn leaky check valve.Just thinking of ripping off this kit and going with a devils own LS1 kit with 2 bar map controller.
J
J
Dave, just a piece of pipe that was flared with the ridge thingies on the ends so the hoses dont slip off. We have an exhaust shop here who does all that kind of stuff. A nice intercooler would be ideal but the incons are out of flow so maybe i'll pick up just a bit of flow without the intercoolers and i always use meth anyway so its a win/win plus 18# off the nose....not much but mine is now around 3900 raceweight
If its decent weather I would say mid .50s if it hooks.
go to work......
