Is this cam to big for a turbo?
Old Mar 23, 2006 | 09:00 PM
Okie02's Avatar
Default Is this cam to big for a turbo?
Actually which of these two cams would be better for a 370ci motor and a t-76 turbo.
232/234 .595"/.598" 115 lsa
228/228 .588"/.598" 115 lsa
which one would be best? or do they both suck for a turbo?
Old Mar 23, 2006 | 09:03 PM
LIL SS's Avatar
Moderator
It's a trade off but depending on your goals I would even think about going a bit bigger. Also not a firm believer in a standard split cam for turbos. Either no split or reverse depending on your intake/exhaust.
Old Mar 23, 2006 | 09:07 PM
Okie02's Avatar
well what would you suggest? im lookin for 700rwhp or so.
Old Mar 23, 2006 | 09:11 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd go single pattern or reverse split. You really want to make sure you don't go too crazy with exhaust duration with a single turbo setup since you will just be increasing back pressure at the turbo.
Old Mar 23, 2006 | 09:23 PM
Okie02's Avatar
i know what reverse split means, but what does single pattern mean? Also what the highest you would go on the exhaust duration and lift? thanks
Old Mar 23, 2006 | 10:26 PM
LIL SS's Avatar
Moderator
Again, cam is going to depend on the whole package.
What is your plan for the full exhaust system?
What are you doing for the intake?
What heads are you running?
Is it a hydraulic motor or a solid roller motor?
How high do you plan on spinning it?
What compression ratio?
Is it a manual or auto?
A single patern means the same intake lobe as exhaust lobe.
Old Mar 23, 2006 | 10:35 PM
Okie02's Avatar
Not sure on the exhaust.
As for the intake im using a fast 90 and NW 90mm TB.
Heads- Stock 6.0 heads
motor is hydraulic
Want the cam to peak no later than 6650rpm
compression ratio will be around 8:9:1
car is a 6 speed
Old Mar 23, 2006 | 10:38 PM
qqwqeqwrqwqtq's Avatar
We use our 225/225 113lsa cam for the 370ci/T76 combination and it has made 908rwhp/908rwtq.
Old Mar 23, 2006 | 10:59 PM
LIL SS's Avatar
Moderator
I would be interested to see what that same combo made with a different cam. Did you guys test other cams and find that to be the best?
Old Mar 23, 2006 | 11:03 PM
Okie02's Avatar
what was the lift on the cam?
Old Mar 23, 2006 | 11:07 PM
.591 at the valve
