Ati #'s 5 Psi
Old 03-29-2006, 06:37 PM
C.W.A's Avatar
Default Ati #'s 5 Psi
I got the procharger tuned today at lingenfelter in dallas with the 5 psi pulley.
I was hoping for 530-540rwhp,but got a gift when it put down 564rwhp and 490rwtq on the first full pass AF 11.9. Then they tuned it a little more and it threw down 582.8rwhp@6200 and 501.8rwtq@4500-6200. They had to shut it off because the feul pressure was falling of past 6000rpm. Now we are going to install a KB boosta pump and retune with more fuel and go for 600rwhp@6400-6500rpm.
Car is badass!
Old 03-29-2006, 06:45 PM
dementia's Avatar
All that at 5psi wow, what engine is this goin through?
Old 03-29-2006, 06:51 PM
C.W.A's Avatar
LS1, my mods are below!
Old 03-29-2006, 06:54 PM
68ss_00ss_87_95's Avatar
damn, thats good for 5#, i have the d1 and my setup is pushin 10-12#s and i have whats in sig....ls6, w/ afr 205 heads, aftermarket cam, ls6 intake and a few other things....pushin rougley the same as you are with 5psi! good job!
Old 03-29-2006, 07:07 PM
C.W.A's Avatar
thanks It pulls like a **** on the highway, I love it!
Old 03-29-2006, 07:50 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
You have superb number there. Congrats.
Old 03-29-2006, 10:29 PM
C.W.A's Avatar
the cam is 230/232 600/607 114lsa!
Old 03-29-2006, 10:37 PM
SSilverSSurfer's Avatar
damn thats perfect.....the blower gods are with you
Old 03-29-2006, 10:43 PM
markp03's Avatar
thats was with the stock pump ? and 32 # injectors? nice
Old 03-29-2006, 10:50 PM
C.W.A's Avatar
no 60# and a racetronic fuel pump!
Old 03-29-2006, 10:52 PM
markp03's Avatar
hehe ok change your sig...says 32 inj in there.... but nice numbers for 5 #!!!! damn hehe
put up a graph if you can.
Old 03-29-2006, 10:56 PM
solobaric's Avatar
WOW!! That is incredible man! Crazy numbers! Congrats!
Old 03-29-2006, 11:33 PM
LSs1Power's Avatar
Very nice.... Whats your pulley combo?
Old 03-29-2006, 11:56 PM
dementia's Avatar
I figured LS1 and I saw the mod list. I shoulda been more clear. Stroked? What size LS1 is what I was goin for.
Old 03-30-2006, 12:00 AM
DeltaT's Avatar
Very nice numbers. What Procharger and intercooler setup are you running?
Was this pump gas?
Jim
Old 03-30-2006, 05:11 AM
EPP
EPP's Avatar
Smile
Car is badass!
Those are great numbers, they might just make Lingenfelters forget about the Maggies they always use... lol
I'd shoot for an air/fuel ratio of 11.5/1 to keep your stock internals alive. Bob
Old 03-30-2006, 07:55 AM
WAHUSKER's Avatar
Great numbers! 6 sp & 10 bolt? Which pulleys are you using? My "5lb pulleys" made around 6 psi @ 6500, 7 psi @ 7k with 9.3:1 CR & an LSX intake. (7.5" ATI crank, 3.85 s/c pulley)
Old 03-30-2006, 08:29 AM
NOIR's Avatar
whoa thats nuts. those are some insanely high numbers for only 5psi! congrats.
Old 03-30-2006, 10:29 AM
LSs1Power's Avatar
I thought the ATI stock crank pulley was a 7.65". You should be seeing more than 7psi. With my ATI setup running 7.65 crank and 4.25 SC i used to see 7.5-8psi.
Now with the SDCE setup Im running 7.25" crank and 3.85 SC pulley and seeing 11psi at 6500RPM.
Never mind you have a P-1SC.
Old 03-30-2006, 10:36 AM
T/A KID's Avatar
I wonder if the cam has anything to do with the Great numbers, reason be I NEVER see Blower cams with 2 degree duration difference, I usually see anywhere between 8-12 degree split with the I/E. Any advance in the cam and what are the specs on the heads, I am trying to understand why your COMBO makes that type of power.
WHat is the valvetrain Configuration, Springs, Lifters, Etc
Quick Reply: Ati #'s 5 Psi
