what gears you guys running?
Old Apr 5, 2006 | 12:40 PM
ZDOG's Avatar
Default what gears you guys running?
im still hashing out between procharger and small turbo but while i cant decide im doing supporting mods. im a m6 and i want to keep my abs so im looking at a 12 bolt. should i stay 3.42 or go to 3.73? im looking for around 500 rwhp. im also looking at cams but i guess thats another thread. thanks
Old Apr 5, 2006 | 12:41 PM
89Formulaws6's Avatar
i've seen alot of guys swapping back to the 3.42's and likeing them better
Old Apr 5, 2006 | 12:44 PM
NA$TY-TA's Avatar
I have 3.73's right now..... in a Strange 12 bolt.
Once my car finally hits the track we will see if i need to go with 3.42's or not.......
Im thinking we will........
How much is the combo going to be driven on the street?? If alot then go with the 3.42's...
Kyle
Old Apr 5, 2006 | 02:24 PM
TrakDay's Avatar
I should have track results from a 3.42 - 3.73 gear swap by the end of the month.
This is on my Procharged GTO...
Old Apr 6, 2006 | 08:05 AM
ZDOG's Avatar
itll be on the street 99.99% of the time. it just sucks to throw out 2500 for the same gears i got ! lol. i got to imagine its hard to keep tracking with a higher gear ratio though. thanks
Old Apr 6, 2006 | 08:00 PM
Darren P's Avatar
if you go with a turbo kit you will want a higher gear like the 3.42
or even a 3.25 or so
it will load the turbo faster and build boost faster giving you more TQ and more useable RPM range
if the engine has to work harder with a turbo it will make more power if the turbo is sized right
Old Apr 6, 2006 | 08:18 PM
frcefed98's Avatar
Thats exactly what i'm hoping will happen when I switch out my 3.73s to a set of 3.23's. The 3.73's never really loaded the turbo off the line and the car didn't get moving until half way down the track.
I'll post up my results when I get the 3.23's in...just need them to show up
Old Apr 6, 2006 | 08:35 PM
ABeasst's Avatar
I'm going with either 3.33, 3.42, or 3.55 gears
Old Apr 6, 2006 | 09:25 PM
macdaddyZ28's Avatar
taller gears make up for lack of torque right?
Old Apr 6, 2006 | 09:43 PM
Darren P's Avatar
A turbo car does not have a lack of Torque
taller gears/lower #s, need more Torque EG 2.73
shorter/higher gears make up for lack of TQ or just help the car got going faster EG 4.30
it sounds crazy but a turbo car needs the engine loaded to make boost faster which means mucho Torque down lower
on my car the max torque was at 3800 RPM on the Dyno but it hits peak boost at around 3400 RPM on the street and peak boost = peak Torque
that is with around 7 PSI boost on the dyno it makes around 8.5 PSI on the street
Old Apr 6, 2006 | 09:46 PM
bboyferal's Avatar
Darren, try to explain that in this thread if you can...
https://ls1tech.com/forums/forced-induction/483757-going-f-i-summer.html
Old Apr 8, 2006 | 08:54 AM
bigturboz28's Avatar
I agree, I have 4.11's with a turbo, might as well take off in second when you consider shifting time. Also 4.11's with even 400rwhp need slicks so you don't spin 'em in first.
Old Apr 8, 2006 | 12:20 PM
93formto98T/A's Avatar
Doing something between a 310 and 325 on my new 9"
