How much boost is needed?
Old Apr 12, 2006 | 01:00 PM
Cbrakllr's Avatar
Default How much boost is needed?
I was wondering how much boost it will take to get 600-650 hp from an Ls1 with longtubes, true duals, lq9 heads, Superchager cam?
Old Apr 12, 2006 | 03:23 PM
Project GatTagO's Avatar
Non boosted HP x (boost/14.7) - HP loss for supercharger = Final HP
sounds right....
Andrew
Old Apr 12, 2006 | 03:30 PM
LSs1Power's Avatar
Check Sig for results. 10-11psi should put u around 600rwhp on a dynojet or 560rwhp or so on a mustang dyno.
Old Apr 12, 2006 | 05:38 PM
C.W.A's Avatar
I'm running 5psi, d1sc with restrictor from ECS 583rwhp!
Old Apr 12, 2006 | 08:45 PM
LSs1Power's Avatar
Whats your crank and SC pulley size? What RPM did you stop the dyno run?
Old Apr 12, 2006 | 09:18 PM
C.W.A's Avatar
4.75 on the SC pulley and I think 8.5 on the crank! the d1 has a restrictor also!
I'm not possitive on the crank pulley. I think you and I have talk about this before! They took it to 6200 and the AF went lean so they stopped!
Old Apr 12, 2006 | 09:52 PM
LSs1Power's Avatar
That will be around 45500 RPM from the D-1SC. I saw 11psi (13psi without the hat) from running my blower at 46300 RPM or so. So i guess there are two possibilities for why you are getting 580rwhp while showing 5psi on the gauge:
1. Messed up gauge.... You need to replace it or try another one just to check if its working right.
2. The heads and cam you are running are flowing soo well that you dropped 4-5psi.
Old Apr 14, 2006 | 05:40 PM
C.W.A's Avatar
what do you mean dropped 4-5psi
checked the gauge and it's working fine!
Old Apr 14, 2006 | 09:24 PM
LSs1Power's Avatar
I mean that at your RPM blower speed you should be seeing anywhere between 8-10 psi at the least. As you know psi is a reading of restriction at the intake manifold. Since you have heads and cam that might affected the boost reading because the engine is taking more air in hence the lower boost readings. Great numbers none the less
