Is a 60mm Tial Waste gate to big for 700-800hp
Just wondering if anybody would know if a 60mm Tial Wastegate is too big for 700-800 hp? The reason i'm asking is because i'm getting a good deal on one.
What do u guys think?
The better question is, "is X wastegate big enough to TONE DOWN the power to where I want it." Wastegates ... waste .. boost, not help create it. They are there to bleed off the pressure that your turbocharger would otherwise use as motivation to spin faster and make more boost ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Of course, there's only, oh, every other component in the system to also consider
Turbocharger configuration/size/etc., engine displacement, flow capability, exhaust system configuration, etc. etc. etc.
In general, 60mm should be sufficient to control nearly anything you'll throw at it (within reason).
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
It really depends on alot of things...A big turbo that you want to run very low boost takes a bigger wastegate than running higher boost. If the wastegate is to small you will get boost creep. When we run say a 76gts on the street and run lower boost we run tial 44 or 46. no problems with creep.
You really need to give some details about your combination but yes 60 is big!
Corey
Clayton Racing Engines
Corey
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by nastysupaspt
well i'm gonna run a 76gts, with a forged 346ci, afr heads, a nice mild turbo cam. This will be a front mounted turbo set up.
