Biggest turbo available for the incon kit?
Spool up is a good 500-700 rpms later BUT my stall is a lot tighter now so who really knows. I tested the t-brake at a light yesterday....4300 rpms saw 13.3 psi on the e-boost2!! Yayyy...it was still climbing too as it made boost. Of course until I put the rear end in, I just let off the gas until its back down to idle and THEN let off the brake.
Nothing real to report yet because of the other probs. My stall seems to flash at idle to 2600 so its pretty tight but it does SEEM to be very efficient up top. Got my daughter with me today so tomorrow will be the first time I get to log a lot and maybe some vids. I have seen 18 psi once...no i/c...15 deg timing and no KR
Thanks
That's a good day!
Your dog must really suck. Sounds like the two way checkvalve broke. Its the one that is fed off the back of the intake(by the map sensor) and is routed to a place right inbetween the PCM and HVAC box under hood. If the vac line pops off or the checkvalve cracks you'll have a vac leak and the a/c will blow out the bottom vents by your feet. If you already fixed it, ignore this bit o' advice.
Autozone sells the replacement 2 way check valve on the shelf for 5.99.
