Biggest turbo available for the incon kit?
Unless you already have an aftermarket tubular K-member, or unless you have the whole engine/subframe on the ground in front of you it's almost impossible to get the ducting and compressor to fit.
I had the k-member dropped 10 inches, the engine lifted away from the k-member and the pedestal for the engine mount removed in addition to the ac compressor out of the car and I barely got the turbo assembly/ducting installed. It was a nightmare and pretty much impossible if the compressor was still in place using the stock K-member.
But I certainly agree with you that it's the best twin kit ever made for the f-body. ~Joshua
Which Tube K-Member would you recommend me getting? That's one extra $500 part that's a part of the hidden costs
P.S... Any updates on the upgradded turbos for cable or onfire?
Damn Jerry!!! 820?!
Kewl..... Damn Jerry!!! 820?!
Kewl.....
@ the 1.5 feet on each side.. that's no joke. Not bad, considering it only took you a week to put in... The Best V8 Stories One Small Block at Time
I wish they would become a sponsor here. Great turbo shop... the best experience possible. ~Joshua
