Biggest turbo available for the incon kit?
Old Sep 26, 2006 | 06:41 PM
  #161
anarchy99's Avatar
Getting a pay raise at work shortly... Then my turbos will be at the same place. Don't suppose they do ceramic coatings also? Could ship it all off to want place. Wouldn't that be nice.
Old Sep 26, 2006 | 07:03 PM
  #162
onfire's Avatar
Coal Mining Director
They do ceramic (Jet Hot) . Here's some triple secret stuff for ya (don't tell Cablebandit...ok) The Incons come with a custom cast TO4B compressor housing with cast mounts for the wastegate actuator.
Mike (Blouch) custom built a TO4E compressor housing mock up turbo for me to trial fit on the Incon kit....if it works hello 60lbs flow per turbo and 1200 potential engine horsepower.
Old Sep 26, 2006 | 08:29 PM
  #163
cablebandit's Avatar
you ***!!! dont think i wont sell mine to get those Mike is awesome...I have never been treated so well
Old Sep 26, 2006 | 10:30 PM
  #164
onfire's Avatar
Dang, I forgot you still posted in here...lol...
BTW, I'm not an official *** until these things fit
Hardest part will be mounting the wastegate actuators...compressors "look" like they will fit with a little hammer mod.
Old Sep 27, 2006 | 12:16 AM
  #165
Mike 01WS6's Avatar
Damn, you guys are nuts! And it is seemingly keeping me from doing ANYTHING until I see your results. I'm your peanut gallery now....how does it feel?
Old Sep 27, 2006 | 05:19 AM
  #166
anarchy99's Avatar
OUTSTANDING... Let us know how it goes so I know if I'm ordering one setup or the other... I'm all about the hammer mod, BTW. SawZaw maod is another personal favorite!!!
Old Sep 27, 2006 | 06:09 AM
  #167
plenty of room on the passenger side...the drivers side is where i think it might get tight but i think its doable.
Old Sep 27, 2006 | 06:11 PM
  #168
anarchy99's Avatar
I wonder if relocating the oil filter would make it easier...
Old Sep 27, 2006 | 11:08 PM
  #169
onfire's Avatar
Some TO4E mock up pics....60lb/min flow per turbo.
Attached Thumbnails Biggest turbo available for the incon kit?-img_0809-large-.jpg   Biggest turbo available for the incon kit?-img_0810-medium-.jpg   Biggest turbo available for the incon kit?-img_0811-large-.jpg
Old Sep 28, 2006 | 12:44 AM
  #170
did you look at the better flowing downpipe part with the wastegate actuator from ATP Turbo?
Old Sep 28, 2006 | 06:31 AM
  #171
anarchy99's Avatar
looking good. how soon till you can mock those bad boys up on your car? Also, if the mock up is successful, what's the price difference between those and the ones cablebandit got?
Old Sep 28, 2006 | 09:18 AM
  #172
onfire's Avatar
Yep, has to flow much more but it's for a T3...emailed them and they never responded.
Old Sep 28, 2006 | 09:20 AM
  #173
onfire's Avatar
End of October, possibly into November since I'm going to redo the Incon system with coating,porting,etc when I take it off.
I'd guess no more than $200 over the standard upgrade.
Old Sep 28, 2006 | 10:34 AM
  #174
anarchy99's Avatar
Hmmm.. Now I have to decide between bigger turbos or a new rearend.... Damn.
Old Sep 30, 2006 | 07:48 AM
  #175
TTSSZ's Avatar
you should be able to push 750rw with your setup, the rear at that level wont last long.
You should get the rear for now, run what you have, get used to it, and do the bigger turbos next season and push for 850 - 900rw.
by then all the bugs will be worked out and youll be ready for more power.
Or you could get the bigger turbos now, run for a bit, blow the rear, and look at the car in the garage till next season when you can afford a new rear.
Old Sep 30, 2006 | 08:12 AM
  #176
anarchy99's Avatar
I like this option better!!!!!!!! seriously, you could make it a little harder for me yah know.
Old Oct 1, 2006 | 01:28 AM
  #177
~JOSHUA's Avatar
Just got my Incon kit back on the 'Hawk. (Thanks Steve-o for the great help!)
On the initial drive @ 1am, I eyed the boost gauge, and it would hit 5psi for a second and then spike upwards. I bet one of the wastegates has a poor seal with the vaccum line... it keeps climbing while the other one stays @ 5psi.
It spiked up to 7-8 and once a quick flash up to 10psi before dropping. I doubt the engine was hurt with those low-rpm pressure spikes. It seemed fine afterwards.
I'm running low boost because I want the car trouble free... for now.
At least it's already tuned. I'll check the wastegates tomorrow and go for a cruise.
Old Oct 1, 2006 | 02:17 AM
  #178
Mr. Bungle's Avatar
I have been having problems with my wastegates as well. I can't get mine to make over 11lbs of boost. If u find anything unusal with you let me know.
Old Oct 1, 2006 | 09:03 AM
  #179
onfire's Avatar
Best way to check them is manually with a Mityvac....easy to do ...just hook the MV to the vac line leading to the gate and slowly pump the thing until the gate just starts to open....you can fine adjust them that way to get each one opening at the same time.
Old Oct 1, 2006 | 11:28 AM
  #180
Mr. Bungle's Avatar
Good tip! Thanks.
