Temps too hot on turbo setup
Mike
Most pusher fans have a lower CFM of air movement, than do the suction application. Having the fans already, I'd look at a way to put them on the back side of the core.
A turbo shield is only going to protect the adjoining components, not cool the water.
If there's a weather seal on the rear of the hood/cowl, I'd take it off. This will allow more hot air to escape.[Old turbo Buick trik]
If the engine is overheating at idle, and in conditions other than in boost, there's likely some other factor[s] that need attention.
1. Exhaust system back PSI.
2. Engine tuning.
3. Trans cooler in rad tank??
Do you still have a/c? If so you might have to lose it. I know that when I was running a/c with my pushers I had cooling problems in traffic in the summer time, the a/c condensor was a big restriction to the pushers and radiator. Once I ditched my A/C that lil problem went away.
If your cooling problem is this bad, you might have to go to a relocated radiator with a large puller fan(s). I know i'll be doing that soon so I don't have to use the heater from time to time in the summer.
J
Hope and doubt that it would be that.I'd get a turbo blanket of some sort. I run a turbonetics heat shield on my exhaust housing because it sits close to the radiator. I will be getting a blanket one day when I'm rich
Are your pipes wrapped with thermal wrap? That should help keep the under hood temps down a lil...might help some too. I'm running wrap on every hot side pipe past from the crossover to the DP back.
Back in the early days of FI for the LS1 Fbody, some of the powerdyne guys were running crazy fan set ups from 2 pushers and one puller to 2 pusher and 3 pullers
I made due with the FAL 240's.
Hope you get it solved.
J
With the rad cap off, can you see coolant circulating?
Also, retarded timing can cause overheating. May be worth a check.
Jim
the headers are powdercoated but no other piping is,all my cold size is aluminum so i thought that would help keep things cooler.as soon as i feel better from puking my guts up,like next week,i can try to hardwire the fans to ignition.coolant does move,and i didnt think of retarding the timing,but i have a feeling its very retarded LOL.i sent over like a books worth of info to NLP and my computer and he gave me the starter tune,so based on how the car acts im running low 11's to high 10's AFR and prolli not a lot of timing at all. Last edited by ddnspider; Apr 27, 2006 at 04:31 PM.
J
thats what i was gonna say.
then u will know what im going through wioth 10 miles on your car.
P.S. i hope its not something like that, i just think its funny.
The way I see it if you are cruising above 50mph there is no reason to even run the fans.The car should be running cool. I can see low MPH getting hot,which will need the fans running.
