Temps too hot on turbo setup
Old Apr 25, 2006 | 06:36 PM
ddnspider's Avatar
Default Temps too hot on turbo setup
Hey guys the install is officially finished. But 1 small snag is that the car is getting too hot IMO. The aerotech scan gauge that i have is saying coolant temps are getting in the 220's.Ive got dual 12" FAL pusher fans a 160* stat etc. Any tips on something i can do to make it cooler?I just bought a 12" puller fan to put behind the radiator to hopefully help.Anyone have any suggestions?thanks Nick
Old Apr 25, 2006 | 06:47 PM
FUroundeye's Avatar
You may have checked this already, but the first thing to do is check to make sure the pusher fans actually are pushing the cooler outside air through the radiator i.e. they're not wired backwards and pulling the hot engine compartment air through the radiator.
Old Apr 25, 2006 | 07:21 PM
ddnspider's Avatar
nope we did the paper test.put a paper against the back of the fans and it sucked it instantly.the race shop couldnt get any more air out of the system either.....help,ideas!
Old Apr 25, 2006 | 07:26 PM
KraZy's Avatar
I've got the same setup and same problem. I'm yanking the AC this weekend.....next steps is new radiator.
Old Apr 25, 2006 | 07:29 PM
DeltaT's Avatar
Since you're in Florida, you can run distilled water and some Redline Water Wetter with little to no antifreeze.
It's given me a Minimum of 20 degree temp drop, and the hot rod and Mercedes both dropped 25 degrees.
If that doesn't work you may need a larger aluminum radiator.
Jim
Old Apr 25, 2006 | 07:32 PM
ddnspider's Avatar
im running straight watter and a bottle of watter wetter,im hoping the other fan helps when it comes,i really dont wanna get a new radiator.could there still be air in the system?or maybe something im overlooking?
Old Apr 25, 2006 | 07:38 PM
LTLHOMER's Avatar
Do you have the air dams in place? Mine gets pretty hot too just cruising around and I'm going to get some turbo heat shields and try putting a stock-type air dam setup back in to direct air up into the radiator. At idle in the driveway it doesn't seem to heat up but at low cruising speeds it starts cooking...up over 210.
Old Apr 25, 2006 | 08:25 PM
blacktransam's Avatar
no his is heating up sitting still and when driving.. we've bled and bled.. theres no way theres any air left..i was thinking a heat sheild over the turbo.. honestly nick at this point i wouldn't waste my money on another fan..
Mike
Old Apr 25, 2006 | 08:28 PM
LTLHOMER's Avatar
Throw more fuel at it at idle/low speed stuff. Maybe some more timing. All of that has an effect.
I am going to do some experimenting once I get my car to work right at wot first!
Old Apr 25, 2006 | 08:34 PM
frcefed98's Avatar
Get your HPT/EFIlive, Fire it up go into the editor adjust BOTH of your fans to come on at 168 deg's.
Also wire both fans so when one comes on both come on. I have the stock harness controlling both fans.
Don't have HPT/EFIlive...then get one of em..
If you have done both of these steps disregard.
J
ddnspider's Avatar
at idle it makes no sense why its getting that hot,but when we test drove it we didnt have the air dam so that should hopefully help when thats back on.would a turbo shield really help?
Old Apr 25, 2006 | 08:36 PM
ddnspider's Avatar
i believe its currently setup to run the 1 fan and the second come on at 18X...when i go for my tune i can have him program 2 of the 3 fans to stay on and the 3rd to come on at a certain temp....but i did get 2psi of boost so i officially have a turbo TA lol and im running pig rich too,thanks to the base tune
Old Apr 25, 2006 | 08:40 PM
frcefed98's Avatar
Get HPT, you can do this stuff yourself...makes its a ton better than running to the tuner all the time.
IMHO, a tuning suite is pretty much mandatory if you are going to start modding your car, especially if you are going FI.
J
Old Apr 25, 2006 | 08:51 PM
ddnspider's Avatar
ya,ive been toying around with the idea especially since 98's can now go 2 bar.but i though itd be a smart idea to take it to someone who knows what theyre doing for such a big buildup as this,and then tinker with little stuff to get my feet wet little by little til im more comfortable
Old Apr 25, 2006 | 08:58 PM
Rusted40's Avatar
excessive oil temps will hurt too
I'm having similar problems on my TT setup and its oil temp related
even with a 9 quart setup
hope the remote oil filter and cooler work
Old Apr 25, 2006 | 09:02 PM
Country Boy's Avatar
Senior Member
Just wait untill August here in FL
Ill be watching this thread
Old Apr 25, 2006 | 09:03 PM
Senior Member
No air dam will make a HUGE difference on our cars. Its the only way the radiator gets air.
Old Apr 25, 2006 | 09:06 PM
ddnspider's Avatar
very true....but it gets too hot at idle as well and on my last motor with my 160 stat my car never went about 170-175.ill let you guys know tomorrow when i drive the car home since itll have the air damn on it.
Old Apr 25, 2006 | 09:07 PM
LTLHOMER's Avatar
True but he's overheating while not even moving...
Old Apr 25, 2006 | 09:08 PM
Senior Member
ahhh... how are you bleeding the cooling system? Ive never had luck doing it the book way. Ive always just left the cap off until the t-stat opens and keep filling.
