Backpressure-what can I do?
Combination Motorsports Outlaw Iron block:
LS1 6.0L iron block
Callies Racemaster 4340 Forged Crankshaft 4.000" Stroke
Callies Compstar Connecting Rods 6.125"
Mahle Forged Pistons 4.030" Bore, -12cc Dish
Mahle Plasma-Moly Piston Rings
PolyDyn Coated Clevite H series Cam, Rod, Main Bearings
ARP Main Studs
Fully Balanced
Assembled short block complete with build sheets
IS BACKPRESSURE GONNA HURT ME? IF SO, WHAT CAN I DO TO MINIMIZE WITH THE PARTS I HAVE???? PLEASE HELP!!!!!!!!!!!!!
THANKS!!!!!!!!!!!!!
Sorry I didn't include this: 10 # of boost maximum!
But it will depend on how much boost you run. You'll need to measure it.
Also I have heard the street kit intercoolers aren't ideal. I have no direct experience with them however. An intercooler upgrade might help your power delivery (but will not affect your backpressure)
I’d make sure you had the biggest of everything that kit has to offer (ie Dp, wastegate, log ect). I don't know where the wastegate on your kit is located, but the newer kits have the wg closer to the passanger manifold, which is better and would definatly help reduce bp. I'd also run a cutout right off the DP, that would atleast let you get a lot of air out of the turbine as soon as possible (also give you a bunch of power). Then there's maybe looking to get a tangental housing on the turbo, but that would also take a little modifaction. That's about all you can do.
The main problem is that your motor could make 500+rwhp WITH OUT a turbo kit. And really, the street kit is made for 500-650 rwhp, so in reality, that turbo kit could be a restriction (I had a similar problem with the T-60 turbo on a street kit). If it were me, I'd sell that kit and get a better on (ie TTi race kit, PTK, Hi/flow, GRM race ect)
Later,
Dave
You might see pressure drop on the cold side between the turbo and the intercoolers but that is not the same thing he is talking about.
You could increase the AR on the exhaust side to mitigate it or go bigger turbo.
Cheers,
Chris
Later,
Dave
Any of these kits allow you to keep AC?
What are my best options to reduce backpressure while keeping what I have?
Thanks to all!!
I think you can only go so big on a TTi street kit. Its like an on-center T76 with a smaller comp. cover? Can't remember. I think the max is .96 A/R. Unless you can find a larger on-center A/R, or talk you're builder into trying to fit an on-center PT88 (which I think PTE makes now), just stick with what you have and don't put any exhaust on it. There are probably some other things you can do with the tune to keep heat out of the log I think...to advanced for me.
Thanks to all!!
Enjoy the ride the rest of the year and if you get bored over winter, add a different kit....8 to 10 psi may make you very happy.
