346ci D1SC power level, is this right?
"D1 set up with A custom bracket and a 8 rib belt set up.conected to a ATI pro engine dampner.It has 55lb injectors high impedence .It has a snow performance methenol {water injection} set up.wich alows you to run much cooler and safer tune up. It has had the larger intake pipe as shown in the picture.THIS IS NOT YOUR AVEREGE SUPERCHARGED CORVETTE.This car has dynoed 578.43 hp and 496.45 tq .The supercharger is still under the warranty . All of the pluming for the intercoolers were sent out to be chrome plated.It has a ss steel braided line coming from the passenger valve cover to a aluminum catch can with breather.The car has long tube headers and off road h pipe with o2 simulators and a B@B tri flow exhaust.It has the ligenfelter fuel pumps and B@M shifter."
The car is claimed to run an 11.60 @ 127mph which seems like a really low trap speed for a 580rwhp car. The car was ran on 6.5psi w/ a window switch activated 50/50 water/meth kit coming on at 4psi.
So my question is can a stock 346ci D1sc make 580rwhp @ 6.5lbs of boost w/ headers, exhaust, meth injection, etc..? Also, wouldn't a 580rwhp car trap a lot higher then 127mph on street tires?
Just curious if this is possible, I know he claims to have the sheet, and has agreed to let us re-dyno the car to make sure it makes the power he says it is making, but I just wanted some insight from some people that may know better then I.
Thanks,
Scott
I was mostly concerned about the power output....I was not aware of the D1SC making that much power at 6.5lbs on a stock 346ci. The traps to me look like a 460-480whp setup....I just wanted to make sure on the potential power output of that blower w/ those mods at that boost level.
If you just typed that quote in to show us, then it's a whole new ballgame.
Jim
