New exhaust manifold option for DIY'er turbo kits???
Old 05-10-2006, 11:32 AM
Hugger Z's Avatar
Originally Posted by 1936FordPU
Gran Prix's are cars right? I wasnt aware they had V8's in them now?
Yup, they started last year with the new GXP. FWD V8 power available in them now.
Hugger Z is offline
Old 05-10-2006, 11:34 AM
DSG
DSG's Avatar
I am assuming that the Impala SS is the same set up?
DSG is offline
Old 05-10-2006, 12:12 PM
Turbo Addict
RICE ETR's Avatar
Great find! I will have to check those out as well.
For the time being, I picked up a set of these:
I've got a good idea for my 3rd DIY kit using these and still retaining my a/c but with stock fans.
RICE ETR is offline
Old 05-10-2006, 12:21 PM
SSU Moderator
RyanJ's Avatar
Where are you putting the turbo? High by the battery tray? That will be an interesting build for sure.
RyanJ is offline
Old 05-10-2006, 12:22 PM
Hugger Z's Avatar
Originally Posted by Wet 1
Well that would kill the idea for my application.
Can anyone confirm what the other manifold looks like????
I looked it up and they appear to be mirror images of each other. When I looked further it appears the one shown above was 12569053. The other side 12569054 looks like it may be flatter (does not extend down as far when mounted) and has an attachment for EGR.
PSJ, I will try to send you some screen dumps so you can post up some pics for reference.
Hugger Z is offline
Old 05-10-2006, 12:40 PM
BLWN1's Avatar
CORE CHARGE: $0.00
GM LIST: $214.00
OUR PRICE: $126.86 each
Partsdirect
BLWN1 is offline
Old 05-10-2006, 12:49 PM
Wet 1's Avatar
Thank you for looking into that!!! Are they symmetrical enough to flip them and use them for a top mounted TT setup?
Pics would be great!
Thanks again for your help.
Wet 1 is offline
Old 05-10-2006, 12:54 PM
ESR
LS1TECH Sponsor
ESR's Avatar
Default question
here is my question will they clear the A/C?
ESR is offline
Old 05-10-2006, 02:01 PM
bigredexpress99's Avatar
you can't use them both from the GP because the rear one dumps in the center, and has an additonal pipe for joing the crossover pipe on. I can't see that working very well...
bigredexpress99 is offline
Old 05-10-2006, 02:02 PM
Or maybe I don't understand what you guys are saying.....
Old 05-10-2006, 02:07 PM
frcefed98's Avatar
Bigred is probably right, the nova guy mentions that the other manifold is unuseable because it has two outlets or something like that.
Smokin, i'm not really talkin about myself and a/c, but for those who want to keep a/c and go with GM manifolds, this might be the hot ticket.
And if it does work with the a/c compressor...and I was to rerun my a/c I'd just keep the DP under the k member as it sits now....
J
frcefed98 is offline
Old 05-10-2006, 02:15 PM
  #32
FUroundeye's Avatar
No, you're right. Here's a link to an ebay auction where someone is selling one of those motors, gives you a good idea of what both sides look like: link
I think I'll give it a shot. I work for an automotive shop, and just called the local GM house we order parts through. They said they could get one for me, and if it wasn't going to work, I could just send it back (provided it hasn't been bolted up, of course... ).
FUroundeye is offline
Old 05-10-2006, 02:20 PM
  #33
LS1Tech Sponsor
Slowhawk's Avatar
Use the truck for the driver side.
Slowhawk is offline
Old 05-10-2006, 02:30 PM
  #34
LS1Tech Co-Founder
Nine Ball's Avatar
Those are LS2 Corvette manifolds, right? If so, I tried my pair off the C6 on the racecar and those outlet flanges run right into the shock towers. No room at all to fit them in the 4th gen. I tried them upside down with the flanges aimed to the front of the car, no room at all there.
But, they might work for my '69 Camaro project
Nine Ball is offline
Old 05-10-2006, 02:31 PM
  #35
frcefed98's Avatar
Exactly Don, Don't need to use both. The truck mani on the driver side and the GP mani on the pass side.
Even if it doesn't allow A/C usage it still outlets better on the passenger side for those with stock K members. Those with stock k members using both truck manifolds have to notch the K member on the passenger side for the manifold to clear it.
J
Old 05-10-2006, 02:35 PM
  #36
LS1Tech Co-Founder
Nine Ball's Avatar
good point, and the Grand Prix on the passenger side should allow more clearance for a big downpipe.
  #37
smokinHawk's Avatar
even if you flip them upside down?
just curious.
smokinHawk is offline
Old 05-10-2006, 02:45 PM
  #38
Z06PSI's Avatar
All 5" of it....
Z06PSI is offline
Old 05-10-2006, 02:58 PM
  #39
MrDude_1's Avatar
lol, both would work good for anyone that plans a crossover over the bellhousing, and to mount the turbo on the back, passenger side of the car... lol.
MrDude_1 is offline
Old 05-10-2006, 06:36 PM
  #40
frcefed98's Avatar
Yep pretty cool huh, there is a section dedicated to those quick family movers here on tech as well
https://ls1tech.com/forums/forumdisp...ysprune=&f=108
J
Quick Reply: New exhaust manifold option for DIY'er turbo kits???
