STS with ATI
Old May 10, 2006 | 10:22 AM
SSnakekiller's Avatar
Default STS with ATI
Here is a customer car we just finished adapting the ATI Twin Intercooler to the existing STS kit:
http://www.jlturbo.com/pics/stsati/stsati.htm
Before the intercoolers with the stock turbo and on the stock rear end it went 11.5 @ 127
Now we have just finished/adapted the intercoolers and are building a bigger turbo for the car. We have also added a 9" (locker) and have a 2-step going in the car
The goal to be safe in the 10's @ 135+ (it is a 6spd)
Old May 10, 2006 | 10:29 AM
quiet_storm98's Avatar
interesting setup...definately adds to the sleeper look, but how does it compare to a front mount intercooler set-up??
Old May 10, 2006 | 10:34 AM
No idea yet...we just finished the intercoolers and have now taken the turbo off to get it built bigger. We have not even driven the car yet. It will be interesting for sure...
Old May 10, 2006 | 10:36 AM
CHRISPY's Avatar
Looks great!!
Old May 10, 2006 | 10:49 AM
seal's Avatar
that car is badass! cant wait to see it run 10s!
Old May 10, 2006 | 12:19 PM
same here especially since i am very interested in an STS kit for myself
Old May 10, 2006 | 07:27 PM
LSs1Power's Avatar
Looks nice.... For any STS owner looking for ATI Twin Intercoolers with the piping let me know.
Old May 10, 2006 | 08:17 PM
TIM Z's Avatar
11 sec. Truck Mod
nice idea!, any IAT #'s yet as compared to a traditional FMIC?
Old May 10, 2006 | 09:41 PM
Somebody09's Avatar
Interesting idea. Is there any way you could reverse the inlet/outlet for the ATI intercoolers? Somehow, if/when I go this route, I'd want the outlets to point towards the center so I could get rid of the ProCharger airbox and run my intake pipe straight up the middle, in front of the A/C condenser. It would also shorten the trip for the charged air to the intercoolers, and reduce the amount of piping I think. But damn, I really like that idea! Flow numbers and IAT numbers are definately something I'm interested in too.
Old May 10, 2006 | 11:41 PM
fenix99's Avatar
Restricted User
for some reason im not too crazy about the idea of the procharger airbox, but will definitely have some people like wAIT is that turbocharged -nahhhh cmon stop playin, seriously? lol ..i dunno but everything esle looks kickass hopefully it runs cooler/better than be4...i would also like to see some numbers to see if the gains are worthwhile with a setup like this..cuz it looks like alot more piping goin in and around all over the place
well good luck and hopefully ill be seeing you JL guys soon. i might be stopping by there to waste some money and see what else i can do to my ride
-Albert
Old May 11, 2006 | 03:53 PM
LastBlack02SS's Avatar
What you can do to eliminate the airbox is buy another Y pipe from ATI like the one that joins the pipes together into the intercoolers and use it instead of the box. This will give you much smoother airflow and less psi drop. If anyone is interested I too have a full set with piping of these intercoolers for sale as i chose the route of FMIC for my STS.
Old May 11, 2006 | 04:42 PM
chuntington101's Avatar
thought you guys where going to be running both a SC and the STS then!
looks very nice though!
Chris.
Old May 11, 2006 | 06:25 PM
We thought about doing that, but we worked with what the owner gave us. We can always swap it out in the future. It is very true...the box is unnecessary.
Old May 11, 2006 | 06:45 PM
Jammer's Avatar
I thought you took spy pics of me trying to put on a d1..while keeping my STS style rearmount... Im busy trying to work out the math.
Old May 11, 2006 | 11:15 PM
SSilverSSurfer's Avatar
thats pretty sweet....
Old May 12, 2006 | 05:47 AM
LSs1Power's Avatar
Running a 2.6 KB and 90mm STS turbo on the back would be sweeet. I can see it happening soon on vettes. The KB will spool the huge turbo really fast. I think the trick is to implement some kind of clutch to disable the KB after certain RPM.
Old May 12, 2006 | 06:32 AM
navymitch12's Avatar
you just run low boost on the kb and a larger turbo for the top end...a kb running 5psi would not be that much strain on the motor and than the big turbo running like 12psi or higher #'s if you got the motor to take it
they have been doing it with the mini's for a while...its a great setup if you got the $$$$$$$$
Old May 12, 2006 | 06:34 AM
no need LSs1power! all you need is a big enough bypas vavle on the supercharger and a little bit of electronics! as you start to get positive presure infront of the blower then yopuopen the valve! then you close the vavle when you are back down to (manifold) just blower presure! easy! lol
it would be very nice to see but i dont think it will ever take off in a big way! far to complex and VERY costly (about 15-8K in parts alone).
thanks Chris.
