How Good Is The Procharger Bypass?
I would say that its belt slip though if the output flat lines. There is minimal contact with a 3.20 pulley considering how hard you're trying to drive the blower.
If you spin the motor to 6600 the blower is spinning to 64478 thats 2478 blower rpm PAST MAX impellar speed.
As effeceint as you motor Sounds you may be maxing out the D1SC at 12lbs I have seen about 3 LT1 style cars with setups like yours and mine max out around 12lbs. I have yet to get mine fully together but I recieved my SDCE setup the other day and I have been wrenching away on my VRE 383 shortblock with LE ported AFR heads.
Another concern though.. I was coming home from putting those clamps on and you all know how we have to "test" to see if it helped. So I put it in 3rd gear around 65 mph (3.73) and floored it and the car went sideways and it was a nice sharp hit from the gas pedal, no delay. Then I tried again since I couldnt watch the boost guage to well and it like bogged when I nailed it.. Then it picked up and took off.. what the hell was that??
I picked up a big K&N cone from a mustang procharger kit off a buddy that used to run a shop, its iterally 4 times as big. Is there no room for more filter or what? Not sure if the stang kit was a P1 or D1, but its HUGE in comparion to the joke in a box i got!
Nick
has anyone tried a Y setup like the split for the twin intercoolers, but on the intake, and run 2 small air filters? Is there room for that? Unfortunatly i havnt installed my kit and probably wont for a couple months, so im not sure what it looks like down there yet.
Country- I have had my silicone 90 on there for about 2 months now and it doesnt show any signs of melting. Just FYI. I also thought about the y for the blower inlet just never went through with it.
