some smoke?
Old Jun 22, 2006 | 08:24 PM
jcews6's Avatar
Default some smoke?
hey im gettin a lil bit of white smoke only at start up of car, and sometimes wide open throttle when it shifts gears, in my drive way we started it up and it only smokes right at start(white smoke) and it was sitting for a lil bit and i notices a lil smoke, but not consistent, i havent lost any power, and my oil isnt milky at all, looks good, im not burning any oil either, what is goin on? i dont seem to be losing coolant either? oh and at startup its only like a 3 second thing then it clears? Help Please!
Old Jun 22, 2006 | 08:45 PM
EDawg's Avatar
rings maybe
Old Jun 23, 2006 | 02:44 AM
Dave D's Avatar
Valve stem seals. This is what I was told when I had the same problem on an IROC I had in college: When the stem seals start to go, they allow oil to pass and drip on hte piston. Not a major amount, but it pools on the top of the piston. when you fire the motor up, it burns the tiny amount of oil, and you get that start up smoke. Mine was white also. I bought the umbrella seals at Autozone for like 50 cents a piece. At higher RPMs it should also pass smoke as your valves are moving quicker.
Old Jun 24, 2006 | 05:00 PM
jcews6's Avatar
Default thanks
but the smoke is like white in color i thought it would be blue if it was seals
Old Jul 11, 2006 | 08:15 PM
jcews6's Avatar
will it do it upon acceleration and after you let off after being at wot for a race or soo it just smokes for a few more seconds after letting off as i come down to a stop again
Old Jul 11, 2006 | 08:17 PM
00turboT/A's Avatar
Headgasket. How much boost are you running????
Old Jul 11, 2006 | 08:25 PM
jcews6's Avatar
7-7.5 lbs, and im not burning any coolant tho and or milky oil at all, and come to think of it its a very light white but blueish, lol hard to explain.
Old Jul 11, 2006 | 10:18 PM
ozws6's Avatar
Is it using any oil? If so, I would pull the intake and see if you see any oil on top of the intake valves.
Old Jul 13, 2006 | 06:43 PM
00turboT/A's Avatar
I would say blowby in the rings.
Old Jul 13, 2006 | 10:14 PM
NAVY's Avatar
are you clearence the rings ???
