low coolant dillema
If its not pulling the coolent from the bottle when it cools off you most likely have a small leak somewhere. Its a closed system and they do it that way to keep air out of the system.
Is anything else happening besides the coolant level? If its not loosing coolant (meaning you don't have to add any), not overheating, not smoking, and no oil/coolant contamination, it might be fine, like KP described.
But in some cases you might be pushing the coolant into the overflow cause you have one headgasket that has a small channel from a water passage to a combustion chamber.
I usually top of the coolant for a few days, and measure how much is being used. When I had an n/a problem, an old motor of mine would use a pint of coolant in a day. I knew it had a bad head gasket.
I'm not saying its not a head gasket, but make sure you filling the thing right first.
