New Twin Turbo system pics
Old 07-18-2006, 09:01 AM
  #101
Silver 00 SS's Avatar
thanks so more cubes require a higher A/R?
btw he stated earlyer that u could fit bigger turbos but would require knoching the frame....
THANKS for the response!
Old 07-18-2006, 09:05 AM
  #102
JMitch19's Avatar
Originally Posted by Silver 00 SS
SEMI TURBO NOOB if no one wants to explain why backpressure is greater with more cubes u dont have to i was just curious, a link would help a lot just want to know more about turbos and turbo stuff i know a little (basics) but dont know all the tehcnical stuff like this any links would be helpful
Scott
Why turbos(of the same size) create more back pressure on larger engines.
Example: If you and Jenna Jamison were to both the blow into the same straw. It would be "easier" for you to blow X amount of air through the straw than Jenna. She has more air to move though the straw than you, due to her cylinder being larger.(or in that case more conditioned for that kind of work)
Not sure if that made sense or not but I just wanted to put turbos and Jenna Jamison in the same paragraph.
Old 07-18-2006, 09:06 AM
  #103
Willem @ Fuel Injection Concepts's Avatar
laymans terms:
more displacement = more exhaust gas = requires larger exhaust orifices to achieve the same backpressure.
Old 07-18-2006, 10:24 AM
  #104
Mekkadon's Avatar
very nice! Will it clear the stock K-member?
Old 07-18-2006, 01:00 PM
  #105
flash12t's Avatar
^^^ like he said will it fit on a "stock" car. .if not what is needed to make it fit .?
Old 07-18-2006, 03:50 PM
  #106
ABeasst's Avatar
he made it using a bmr k-member and CSR starter. those are the only 2 things that should affect the fitment.
Old 07-18-2006, 04:01 PM
  #107
bmfcamaro's Avatar
ya i think the starter is the big must because the clearance there is minimal. this is a bad a$$ kit. i would love to have one.
Old 07-18-2006, 06:38 PM
  #108
slow's Avatar
Sorry if I missed it, any links to this CSR starter?
Thanks
Ryan
Old 07-18-2006, 07:42 PM
  #109
arality's Avatar
I belive this is what starter they are talking about:
http://www.csr-performance.com/Merch...tegory_Code=S2
Old 07-18-2006, 08:28 PM
  #110
Somebody09's Avatar
Originally Posted by JMBLOWNWS6
Man Im glad I waited to see what new kits come out.
Originally Posted by FANTAZ28
wow jim, it turned out AWSOME..... for a street car that someone wants to keep all the acc.
Originally Posted by 1bdbrd
is there any plans to sell just the manifolds themselves? i would actually pay a good bit of money for these in the future because i really want to keep a/c...
I was set on getting GMR's but this looks so much better! Besides, I don't think they're even trying to do that whole A/C relocation thing anymore.
One more thing... are you affiiliated with the two ladies below?
If so, when I come to drop my car off, I'd like to met them.
Old 07-18-2006, 11:51 PM
  #111
qqwqeqwrqwqtq's Avatar
Yes, as every part on a car should be selected to compliment one another, engine displacement and turbocharger selection should be matched up to meet target power, response, and rpm range.
The GT35R's are (IMO) a perfect match for stock displacement. Try to run much more and you just hurt yourself with excessive backpressure and a reduced RPM range.
Typo on the starter, it is actually a CVR (Summit racing sells them).
And yes, the system was built around a BMR k-member, stock will not work.
As far as the dual exhaust question. The y-pipe terminates at 3.5in. I think the best exhaust option would be a Mufflex single 3.5 system with the Magnaflow muffler. This would cause no drop in power and you would have an exhaust all the way out the back.
IMO there would be little to no gain with duals. (except for noise)
Old 07-19-2006, 01:16 AM
  #112
C Murda's Avatar
so any chance of this working fine on a 427?
Old 07-19-2006, 02:40 AM
  #113
NKAWTG...N
StoleIt's Avatar
I doubt it with those mentioned turbos, and it seems like to fit bigger turbo's youd have to notch the frame and get some different parts.
Jim explained better in a few of his previous posts, so read up.
Old 07-20-2006, 07:14 PM
  #114
MstgKillr's Avatar
When can I place my order?
Old 07-20-2006, 11:06 PM
  #115
Moderator
FANTAZ28's Avatar
contact speed inc.
847-891-0767 but i belive they will not take orders till they have a kit done...
Old 07-21-2006, 08:18 PM
  #116
PRAY HRD's Avatar
any chance of getting the manifolds only.......in stainless?
how about a forward facing stainless pair???
feel free to pm me if you'd like to.
thanks.
Old 07-21-2006, 08:22 PM
  #117
BW
BW's Avatar
will this kit work on my lexus?
Old 07-21-2006, 08:34 PM
  #118
MstgKillr- Not exactly sure yet. We are finishing up the fixtures tomorrow and starting on the 2nd system next week.
PRAY HRD- We will initially just be offering complete systems, which may or may not change in the future. It's unlikely that I would duplicate the manifolds in stainless as I believe they would be more prone to cracking in this application due to higher expansion rates (and being less ductile).
If you wanted some custom forward facing headers we could do that for you through Speed Inc.
BW- yes, this system is a direct bolt on for 98-02 F-bodys, 98-02 GS400's, and 71 International Scout diesels.
Old 07-21-2006, 08:55 PM
  #119
Ling_650vette's Avatar
Need any test vehicles for the 2nd or 3rd system? lol
Would be nice to see what a high milage LS1 would do w/ twin turbo's.
Then after I blow it up, I can get my forged 348!
Old 07-21-2006, 09:02 PM
  #120
BW
BW's Avatar
will my car make sounds like an import, but in all reality it's a camaro.
Quick Reply: New Twin Turbo system pics
