any ideas on this? graph inside
Old Jul 21, 2006 | 10:18 AM
MIGHTYMOUSE's Avatar
Default any ideas on this? graph inside
this is from the w2w mustang dyno
the horsepower / tq peak was roughly at 17psi no meth, 100 unleaded
after this my friend rob and i added .060 valvespring shim to the comp 921's as prescribed by kurt and this did not change the graph
i'm pm'ing jose to see if this is something to do with the t-4 pte-88 i got from him
the idea is that it is either that the turbo is surging, or that the cam (stock z06) is just wrong for the combination (or some mix of the two)
the second attachment is a local dynojet for comparison (had the old larger w2w turbo cam, and a turbonetics 76mm t-4 turbo (bost cooler results)
im working on getting ahold of the old cam to put back in
Old Jul 21, 2006 | 10:21 AM
cablebandit's Avatar
David, this aint it I'm sure but mine was just doing that with a cylinder misfiring
Old Jul 21, 2006 | 10:22 AM
onfire's Avatar
Coal Mining Director
Is there a psi setting that makes the new combo dyno smooth at a lower hp?
Old Jul 21, 2006 | 10:24 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Dave the turbo is unrelated in erratic curves like that. Only time we see problems like this is engine misfire, or the wastegate is fluttering. Also surging like you asked in your PM would be noticed loudly when under that high of boost. Can you hear anything under boost at the top end??
Jose
Old Jul 21, 2006 | 10:25 AM
this is the low setting
we saw no indication of anything abnormal with the engine, could you post your graph with the misfire?
i switched to truck coils, and it didnt go away, even switched back to the car coils and same thing. i also had a couple sets of wires and plugs in the car with no change
Old Jul 21, 2006 | 10:28 AM
we couldnt hear anything abnormal, and the boost was increasing during the pull ending just shy of 20 at max rpm
Old Jul 21, 2006 | 10:31 AM
LS1TECH Sponsor
Hmm, I would check then the plugs if you have checked all your other options. Does this happen under low boost conditions as well?? Also have you tried to see if this happens on race fuel alone??
Old Jul 21, 2006 | 10:33 AM
GrahamHill's Avatar
Are the other plugs different gap or heat range?
Old Jul 21, 2006 | 10:34 AM
yes, ive been workign on this since november
ive put new plugs in before, and the power is smooth when i drive around town so i would say very very low boost as in vaccum is not affected.
yes. the wheel dyno is race fuel alone, and the previous work was all done on pump gas or pump gas and methanol
Old Jul 21, 2006 | 10:38 AM
ive had a set of tr6's in, autolite ar3911's and the ngk 7173s are currently in
Old Jul 21, 2006 | 10:52 AM
here is the thread i made from before i switched cams
https://ls1tech.com/forums/forced-induction/384407-help-me-pick-another-cam.html
Old Jul 21, 2006 | 11:32 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Let me know if you want your old cam back, it's still in the same box. I need to know by Monday because if I order a new one it takes some time to get it cut.
Old Jul 21, 2006 | 12:04 PM
Cyborg's Avatar
I don't really know what I'm talking about, but is it possible that even more valve spring is needed? Or octane? How's the A/F look up there?
Old Jul 21, 2006 | 01:22 PM
a/f is 11.5 plus or minus. 100 is way plenty at this boost, i have knock control and it was at 0 the whole time. (19* advance)
also at this boost pressure of 17 my exhaust backpressure was 25 = 1.47:1
Old Jul 21, 2006 | 03:05 PM
stevieturbo's Avatar
How much lifter pre-load is there ?? Could valve "clearances" be too tight ? perhaps causing them to hold some valves open slightly at higher rpm causing it ?
Maybe try a shorter pushrod, or shimming up the rockers.
Unlikely, but should be pretty easy to try.
Old Jul 21, 2006 | 03:50 PM
Country Boy's Avatar
Senior Member
It looks like valvetrain to me. I had some serious valvetrain issues and my graph looked exactly like that but I was n/a.
http://img.photobucket.com/albums/v6...rainissues.jpg
Old Jul 21, 2006 | 04:54 PM
NA$TY-TA's Avatar
scrib.....
Old Jul 21, 2006 | 04:59 PM
flynbludream's Avatar
Why are you plotting engine RPM on your y axis?
Old Jul 21, 2006 | 10:14 PM
that is how the graphs were given to me by the dyno operator.
country boy.. what did your valvetrain 'issues' turn out to be
kurt checked the lifter preload to be OK..
Old Jul 21, 2006 | 11:09 PM
whynot's Avatar
on mine, I happened to miss one of the grounds that I had undone, and would only miss on the top end, on boostaholics, a fouled plug was causing a low end miss, so mabey something with your ignition would be my guess.
