Re-locate the STS oil line
Old Jul 26, 2006 | 03:57 PM
jggarrid's Avatar
Question Re-locate the STS oil line
I have a STS turbo syetem installed on my Z28 (LS1 1999) and currently am removing the engine due to a piston ring problem (blown).
Now that the engine is totally out of the car, do you guys have any idea if I can locate in a different place the oil line from the turbo? By now it is located on the oil cap. I was wondering if any of you have drill a hole on the oil pan to install there that STS oil line. OR maybe you have any other suggestion.
Thanks a lot for the help, and any suggestion or commment will be greatly appreciated.
Old Jul 26, 2006 | 07:32 PM
trtturbo's Avatar
We do the return in the shallow part of the pan in front of the rack.
Old Jul 26, 2006 | 07:34 PM
MiaSSmaro98's Avatar
cant u post a pic trt?or a cheap drawing done on the computer
Old Jul 26, 2006 | 07:55 PM
trtturbo's Avatar
look at the front of the pan.
Old Jul 26, 2006 | 08:10 PM
yeah but the oil has to travel back up the 90 degree fitting isnt the bad or it doesnt matter seens the sts uses a return pump?
Old Jul 26, 2006 | 10:40 PM
trtturbo's Avatar
The STS uses a return pump. Its easier to get the oil to the pan then up to the oil fill cap that the STS usually uses.
Old Jul 27, 2006 | 05:27 AM
EPP's Avatar
EPP
Thumbs up
This looks like the best way to do the oil return that I have seen. Bob
Old Jul 27, 2006 | 12:43 PM
jggarrid's Avatar
Thanks for the pics Billy (TRT).
Any special tips to prevent oil leak from that hole?
Saludos, desde Mexico CIty.
Alex
Old Jul 27, 2006 | 01:09 PM
trtturbo's Avatar
you may tig a bead aroung the hole so that when you tap it you have more meat to tap into.
