Finally got it started again
Old Aug 3, 2006 | 07:28 PM
Bryan Wilkinson's Avatar
Default Finally got it started again
Monday night, I finally got my TA started again for the first time since May 05 since the mishap with the C5-R. This is with the new 402 CI LS2, motor and F1-C blower.
So hats off to the last motor that More Performance built. It fired right up and ran for about 40 minutes. We drove it around for a little while and gave it a very little nudge and saw 8psi. I thought for sure I was seeing things.
Then today, one of Michael Waltrips guys was driving it, and gave it a little nudge to 4500 rpm and 19psi. The gauge we are using has a recorder function so that's how we know.
This is with the GMPP intake and custom plenum and 2000 CFM air filter and nice big plumbing from the filter to the blower. I posted pictures a while back.
I hope to have it on the dyno this weekend and at the track early next week. Same guy will be driving it.
Nick and Bob from Williams Performance in Moorseville, performed some tweeks on the tune to get it purring along and did a fantastic job so my hats off to them. Eric Youst did a fantastic job on the fabrication work.
I will let everyone know how it does. 19PSi @4500 for me is a lot of boost aka restriction however you want to look at it. Before with the F1-R, and filter on the blower, I had to work to get 15psi.
Old Aug 3, 2006 | 07:41 PM
Boostaholic's Avatar
Wow thats quite a bit of boost you have there
Old Aug 3, 2006 | 08:15 PM
Darren P's Avatar
Bryan
I want to see this beast run
BTW
did you get that 2 bar map sensor we were talking about
if you did was it plug and play
I ordered the same one from GMParts on Wednesday
Old Aug 3, 2006 | 08:49 PM
Nickn20's Avatar
looks like he needs a 3 bar sensor and tune now, unless he went BS3 or something. that is a lot of boost whats the pulley combo on there and heads and cam setup?
Old Aug 3, 2006 | 09:31 PM
nitrorocket's Avatar
You still doing the pumpgas thing!!!
Old Aug 3, 2006 | 09:51 PM
SSilverSSurfer's Avatar
are you a 6spd or auto?
Old Aug 4, 2006 | 08:40 AM
Originally Posted by Darren P
Bryan
BTW
Hey Darren, Hope you had a great time at the beach!!!!
The 2 bar on this car is the same as we talked about. But after reading the HP Tuners site, it appears the 2 bar for the GTO Twin setup will be a 2.5 not 2. So hopefully someone here will produce a part number for us so we can get your and mine setup!!!
Old Aug 4, 2006 | 08:43 AM
That was my original thought as well, but some things are coming up for this car, and I am going to hold off and keep the 2 bar for now. In my opinion we are only talking about WOT right?
as for the pulley combo, I am using the True tech performance Steel braket (just ilke the bracket from ATI, but in steel), the blower pulley is the 3.83, and the crank is the 7 7/8 inch from the now defunct Morgan Motorsports.
Old Aug 4, 2006 | 08:44 AM
Don't pick now!!!!!, Yes, I am still doing the 93 OCT thing.
Old Aug 4, 2006 | 08:52 AM
MstgKillr's Avatar
post the pics please
Old Aug 4, 2006 | 09:38 AM
ty_ty13's Avatar
7 Second Club
whats the gear ratio on a f1c? and what rpm will you turn the motor?
Old Aug 4, 2006 | 11:51 AM
Blackbird's Avatar
with only a 2bar your only good up to 14.7psi after that your flying blind.
seems silly not to go 3 bar, but if your bent on staying 2bar if your tuner is good he / she can make it work.
Old Aug 4, 2006 | 12:57 PM
2000 Tran Zam's Avatar
ya i was gonna say why are you running 19 lbs if you only have 2 bar on it?
Yep but there will be a rich spot between 14psi and max boost.
Old Aug 4, 2006 | 01:11 PM
StoleIt's Avatar
NKAWTG...N
Your C5R was a 427 ci right? If nothing else was changed in your setup except going from 427 to 402 that would probably account for the greater restriction thus the more boost.
Old Aug 4, 2006 | 02:46 PM
Got Me SOM's Avatar
can you post the pics of the new setup?
Old Aug 4, 2006 | 05:49 PM
6 speed
Old Aug 4, 2006 | 05:51 PM
Gear ratio is 5.73 motor will not be turned over 6000.
