LT1 single turbo project beginning soon
.... what do you expect anyways.. im a plumber... always got to check for leaks to make sure!!! Now i didn't cut the bumper support because i didn't have anything handy to cut it with. I will go back later and do it, but this will be fine for now.
mounting brackets i made for the intercooler
oil drain. that was a PITA... here it is, hadn't cleaned it all up yet
a couple of fans in front of the griffin
lil over view
Anyone have any tips on that gay *** stainless line crap? I have never used it before and the fittings are kinda pain in the *** to get on the line.
But i'm sure you know that.. you have a helluva setup yourself by the sounds of it
If it wasn't high enough, superchargers wouldn't come with instructions telling people to put the drain at that spot.
The drain ain't what im scared of. I went over kill on it anyways (5/8"). The lil bits of metal that probably got into the pan is what im kinda nervous about.
Seems to be working out so far. Turbo is getting oil, No exhaust leaks that i know of yet and no smoking. So hopefully i won't need a restrictor. Really wish i had a clear line to put on as a oil drain to make sure all is good but I guess i'm trusting god (and the fact i know oil is GETTING to the turbo).
But that is the current update... Can't wait now. The turbo comin in is orgasmic!!
I hear ya!! Looked like it was pointing down a little...like closer to the bottom!! Lookin good glad to hear its runnin!!
step one : remove lt1 front fascia and throw that ugly **** in the garbage
step two " install 98+ trans am front fascia
Got trickflow elbow and filter on turbo now. Drove it a lil and seems to check out ok. Injectors are on the way then need to load up a tune...
piece by piece...
When do you expect to have yours runnin'?
can't wait for some track #'s or Dyno #'s.
