my T/A smokin vid.
Old Sep 5, 2006 | 05:50 AM
nick97ta's Avatar
Default my T/A smokin vid.
I installed a .060 n20 jet and stll had this much smoke comming from the car.
Ive got the problem under control now.it takes a min. for the car to show up, but well worth the wate!!!!!
http://s8.photobucket.com/albums/a37...t=TurboTA3.flv
Old Sep 5, 2006 | 06:27 AM
Country Boy's Avatar
Senior Member
wow.... did the restrictor fix it? Thats a TON of smoke.
Old Sep 5, 2006 | 07:26 AM
bowtieman81's Avatar
Ha, that looks like my car before the PCV got straightened out. What is your oil drain size, and how much of an angle do you have on the oil drain?
One other thing you may try is taking your drain off the oil pan and starting the car to see how much flow you get. You can then get some clear tubing from Ace and use it temporaritly to see how much is flowing into the pan
Old Sep 5, 2006 | 07:30 AM
Ping King's Avatar
just drive around in circles and you can tell some ricers youre drifting!
i know what youre going through haha believe me.
Old Sep 5, 2006 | 08:25 AM
RealQuick's Avatar
Nice!
Old Sep 5, 2006 | 05:21 PM
SilverSS's Avatar
Holy smokes! I thought you waisted the front end of your car for a second there.
Old Sep 5, 2006 | 05:56 PM
TransAm6383's Avatar
what size cam is in your car?
Old Sep 5, 2006 | 06:04 PM
Superman09's Avatar
LS1Tech Sponsor
thats a lot of smoke but that sounded AMAZING when you got on it.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Sep 5, 2006 | 08:56 PM
nick97ta's Avatar
the oil restrictor stopped the smoking.
the cam is not for boost,Im going to build a better long block with 210 afr's and 9.0:1 cr and then I will install a better cam. the cam is 284-296 512-513lift on 112 lobe sep.
the new cam will be something in the 290 duration 600 lift and 116 lobe sep.
