Tc76 Arrived!!!!
I'll post up pics of my pressure testing rigs so others can copy em, great to have if you have a FI car.
J
Chris.
PS.... have you investigated the turbo at all? and is there anyone close to you have who has a similar sized turbo you could try, too eliminate the turbo as a possible cause.. just worries me that two similar instances unexplained with the same units.
Nope no one close to me with a T4 flange that I know of. I got rid of all my other turbo's as well to buy this one.
I'll have to ask around to see if I can find a 76 or 74mm T4 flanged turbo around here.Thanks for the heads up, do you have a link to the post so I can read up...I really hope this turbo doesn't max out at 9psi on a small 346-348ci.
He is stuck at 7psi and drops to 5, i'm stuck at 9psi and it holds it there but doesn't go up or down, just stays at 9psi
So tis why I made my pressure testing rigs. I also ordered some new carbon gaskets for the headers, T4 flange and my truck manifold flanges, to help seal up any leaks that could be there.
J
Dr. Turbo do you have a recommendation on the two units? BB or std?
keep us posted on the pressure testing man.. following along with ya!!
Chris
Chris
As for BB vs Non BB. Well Jason and Jose both preach its not needed on a larger ci engine. So far what I have seen personally I tend to agree. Its not worth the extra added cost unless you are just looking for every bit of extra spooling rpm possible. Then maybe so...
I was just curious as Jose directed me to these threads and I saw he had mentioned that the BB unit was a big bang for the buck but I guess he had not had a chance to put these TC76MPS units to the test yet at that point and found they were not needed.. do they use a 360 race bearing setup or is it the 270 style.. just curious.
and is there anyways you could explain to me the difference between the TC76 and the regular T76 units listed on your site? is the shaft diameter bigger in one then the other and is one more reliable then the other.. thanks in advance for the answers Dr. Turbo!
Chris
But will not help me solve this issue, can't drive it around with a blocked off WG
lcvette,
yeah I wish I had some fresh eyes to help me out with this, but everyone that I know disappears when I ask for a hand
Glad you are helping out and throwing things out there. Me and my dad came to the same point as you, maybe something is causing the turbo to stall somehow, but then the car is keeping at 9psi...if the turbine stalled it would drop and then come back up, right?
The WG is still hooked up with the ref to the top port as we speak. I did that and after it didn't work I kinda gave up for a couple days....week(s) on it. I hate when I don't make progress on something that should be real simple to figure out.
I see all these guys from newbs to pro's making great power and numbers with turbos...and it kills me that my car is sucking so bad
Chris
Also yes they are full 360. Not many turbos use 270 anymore except older diesel units. As for the difference, its cover, backing plate and some other small pieces..other then that its the same.
thanks in advance!
Chris
thanks in advance!
Chris
If your looking for most power between the 2 (being 76GTS and TC76) the 76GTS will outpower it by 100 crank hp...not rwhp. The only difference internally is the turbine wheel, which the MPS is almost as large but aerodynamics are awesome and lighter. The GTS-trim flows good due to shear size, but is a heavier wheel. Money no object I would be flipping a coin though between the 76GTS and the T-series 76MPS (not the TC). It has the larger compressor cover to match closely with the 76GTS, and they are both priced the same. Now if you can fit a T6, then go S76, it will slaughter all the above....lol.
that being said... for the money and the warranty I am still firm on the TC76MPS and will be contacting Jose or yourself as soon as my funds arrive.. (had to break into the 401K after the motor rebuild and parts replacement chewed up my fun money savings)
have you noticed a difference in spool between the regular T76MPS, PT76GTS and the TC76MPS? and what are the dimensions of the MPS wheel Vs. the GTS wheel? sorry for all the questions but I know they are things I am curious about and am sure others are as well and may help people make their decisions.
Chris
I know this turbo can make more than 9psi(*edit* I'm really hoping it'll make more up here than 9psi LOL)
I just botched something when it was all apart. My vacuum is low(but then again I have a huge cam) but steady, indicative of a manifold leak.....
J
J
You know it can make more because with the BC out it made more right?
J
233/244 .578/.602 on a 115 is whats in there now, old blower grind.
