Tc76 Arrived!!!!
Old Oct 26, 2006 | 01:13 AM
  #101
TransAm6383's Avatar
hope you figure this out soon..im looking at getting one of these turbos...do they go any bigger than 76mm?
Old Oct 26, 2006 | 10:47 AM
  #102
DrTurbo's Avatar
LS1TECH Sponsor
76 is the largest impeller you can run with that turbine wheel. Jose won't have anything built that exceeds his 30% rule.
Old Oct 26, 2006 | 12:44 PM
  #103
frcefed98's Avatar
Don't let my isolated problem hold you back from getting one of these turbos. They are a great deal, especially the warranty.
J
Old Oct 26, 2006 | 08:16 PM
  #104
52172's Avatar
Yes listen to forcedfed I just bought one also have yet to run it with my HI-FLO kit! This turbo will make 850 reliable RWHP with race gas on a forged 347 short. No doubt about that.
Old Oct 26, 2006 | 09:44 PM
  #105
52172's Avatar
Is the MPS wheel actually a larger diameter or steeper pitch same size?
Old Oct 26, 2006 | 10:12 PM
  #106
DrTurbo's Avatar
LS1TECH Sponsor
The MPS turbine is close to the same size I believe. But the tip and blade height is much taller and the pitch is much more aggressive.
Old Oct 26, 2006 | 11:21 PM
  #107
52172's Avatar
is there any thing that distinguishes an MPS wheel?
Old Oct 27, 2006 | 11:00 AM
  #108
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Looks or power wise??
Old Oct 27, 2006 | 12:04 PM
  #109
52172's Avatar
both if you can thanks Jz
Old Dec 4, 2006 | 03:57 PM
  #110
THE_SUPRA's Avatar
looks nice sir!
Old Dec 4, 2006 | 04:02 PM
  #111
frcefed98's Avatar
Thank you sir, and its still suck at 9psi LOL!!!!
Old Dec 4, 2006 | 04:11 PM
  #112
NA$TY-TA's Avatar
Why Jer??? Any updates????? Plans???
Kyle
Old Dec 4, 2006 | 04:41 PM
  #113
DrTurbo's Avatar
LS1TECH Sponsor
Sounds like a leak somewhere in the system. 9psi just doesn't add up.
Old Dec 4, 2006 | 07:04 PM
  #114
frcefed98's Avatar
I don't know, it kinda adds up until I see results from others with this turbo.....especially here on tech. I know plenty have bought this particular unit but so far no one has posted up on what it has done on their set ups...maybe 9psi is all it can muster on an LS1
But you are probably right, a leak somewhere in the system....I'm eyeing the BOV and that damn WG clamp....Tial sure used a cheap *** clamp to attach it to its flange, I wish I could find the right V band clamp to use instead of that cheap one they included in their kits.
Kyle, check in the post in the moderator section, but the short of it is with a new house going up, Jen working and going to college full time and me building Erics turbo kit, I haven't had anytime to really even look at the car. **** I made up a nifty pressure testing set up that can be used on the car to check for leaks, but haven't had the time to hook it up.
