head gasket bummer
MLS are are Multi Layer Steel or Shim gaskets, pretty much same as Cometic, except sensibly priced.
working on drivers side now, ups just delivered the new gaskets, will illustrate later.
will do the copper spray and 90# unless someone give me a good reason not to
i will probably leave the rockers and headers off until the morning so that i can retq them again at 90, gives me a reason to stop
Copied from web site...
The most dramatic difference between the World Warhawk and factory LS1/LS7-C5R race blocks is the provision for two extra head studs per cylinder. This, of course, greatly increases the amount of available head gasket clamping force and more evenly distributes the load—providing the necessary sealing for high combustion pressure applications (superchargers, nitrous oxide, turbos).
Its just going to be a fact when ya really try and push it....... sooner or later it happens.
http://www.fastrides.com/photos/mm/picture14121.aspx
i waited a couple hours after doing 90 and checked them at 95 and only about half of them moved. finished everything up around 8
I have spares of most gaskets etc...but when ya live 5000miles away, its even harder to get them urgently !
