head gasket bummer
Old Sep 11, 2006 | 02:10 PM
  #61
longrange4u's Avatar
Originally Posted by Slowhawk
We pull our heads after every race weekend to check them.That is only a 800hp blower car.
So what would be reccomended maint cycle for this? Pull heads, inspect and replace the gaskets every 30, 40, 50 passes? Every three months of regular driving? What do you guys think?
Originally Posted by kp
I'm hard on the car since I just can reach over and crank a **** if I want 100 more HP
What are you using for a boost controller?
Old Sep 11, 2006 | 02:25 PM
  #62
maddboost's Avatar
i think Kevin mistyped since he doesnt have a boost controller its a blower car.
Old Sep 11, 2006 | 02:34 PM
  #63
kp's Avatar
kp
Yep meant to say I CANT just reach over and turn up the boost..
Old Sep 11, 2006 | 03:08 PM
  #64
MIGHTYMOUSE's Avatar
i would say when you start to push water it's time to change them
i have bs3 set up to command my air fuel and auto correct for it. my 02 sensor was verified correct just a short time ago
i think i didn't have enough octane
Old Sep 12, 2006 | 11:57 AM
  #65
kp's Avatar
kp
FWIW here is the other side on mine, 3 out of 4 were leaking pretty good. There is no doubt some combustion was getting in the coolent - just dont know exactly how much..
I dont think overtorqueing and copper spray is going to help me out any, I checked every bolt and they were same as I torqued them originally so I dont think a heat cycle retorque is going to do anything.
Maybe some thicker deck heads like AFRs or something will help me out some - but I can buy a lot of GM MLS gaskets for what a set of AFRs cost
Old Sep 12, 2006 | 12:38 PM
  #66
LASTLS1's Avatar
6 Second Club Moderator
I'm not sold on the thicker head issue. I have ET heads and half inch studs torque to 100 lbs. I'm on my third set of head gaskets. I'm also running c16. As stated earlier it's the head design, it will only handle so much pressure. The only way I've seen high cylinder pressures work is with copper head gaskets and oring-receiver grooved set ups! That will be done on mine this winter.
Andy
Old Sep 12, 2006 | 01:07 PM
  #67
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Even with copper head gaskets and o-ringing, guys like the OH Boys will push some water. Kurt views coolant as a consumable.
So Kevin you think you had detonation and had your tune over the edge a little bit?
Old Sep 12, 2006 | 01:25 PM
  #68
PurEvl's Avatar
Originally Posted by MIGHTYMOUSE
im pissed i can't race tonight, i've discovered i'm moving about a cup of coolant to the overflow during a 1 gear pull on the 'test track'
i checked the torque on the center head bolts, were tight, and i bought a new 20psi rad cap, same situation.
i have a fairly small relocated overflow and am not interested in overflowing or bursting it going down the track
i'll be sitting out tonight and replacing them with another set of stock ls2 gaskets tomorrow
i believe the tq to the studs was 80# should i stick with that or go more? stock arp replacement studs, 6.0 ls2 alum block.
i also have some copper gasket spray that i used before on cometic gaskets, think that is a good idea this time around?
any advice (other than turn it down)?
i'm running around on a set of 11.5" 17" et street slicks now and they hook up ok in 4th.
I went to 85 with my arp head studs, i havent popped anything all year even at over 820rwhp on pump
Old Sep 12, 2006 | 01:28 PM
  #69
LS1Tech Co-Founder
MM have you made any passes with the 990rwhp combo?
Old Sep 12, 2006 | 02:21 PM
  #70
nope, that was the plan last (and now this) friday, i will surely not start at 22psi immediately, nor go that far now that this has happened.. dont feel like blowing another saturday under the hood right away.
Old Sep 12, 2006 | 02:37 PM
  #71
Slowhawk's Avatar
LS1Tech Sponsor
Thats the trick.This car isn't tuned for max hp.Timing is at 14 degree's and A/F is safe at 11.5-1 or so for the 15lbs. We could add timing and probly hit 900+rwhp but that would probly hurt the gaskets on 93 octain.Been there,done that
Old Sep 12, 2006 | 02:49 PM
  #72
PurEvl's Avatar
ya my tuner is pretty good
Old Sep 12, 2006 | 02:59 PM
  #73
Slowhawk's Avatar
LS1Tech Sponsor
Tuner has nothing to do with it. All to do with the engine builder
Old Sep 12, 2006 | 03:17 PM
  #74
kp's Avatar
kp
I dont think it was detonating bad, never had any signs of it at all and the car was running well.
I ran copper gaskets/o-rings on my bigger 706" DRCE nitrous motors and trust me they arent blow proof even with 5 bolts a cylinder It does what it does and you cant change the design, you can either push it and accept the work or tune it safer/slow it down and it will live for a long time.
Here is a couple pics of my GM graphite gaskets from last year after 136 passes. They were leaking some but it doesnt seem as bad as the MLS. Just part of the deal
Old Sep 12, 2006 | 05:59 PM
  #75
NA$TY-TA's Avatar
Andy
Anyone know how much extra that is when a motor is being built??
On my next motor ill do it..... Ill do an Aluminum 370 from W2W also......save an extra 90lbs too
But hopefully not soon
Kyle
Old Sep 13, 2006 | 03:46 AM
  #76
jstpsi's Avatar
I know this might sound a lil nuts but what if you had longer sleeves slipped in the block which hung out over the deck a pinch , and machined the perimeter of the chamber to accept the sleeve and literaly dowel the head to the block? Im sure somewhere along the line this has been done but on an lsx?
Old Sep 13, 2006 | 07:53 AM
  #77
hellbents10's Avatar
LS1Tech Sponsor
I am with Kurt.....coolant is consumable.
Old Sep 13, 2006 | 08:55 AM
  #78
LASTLS1's Avatar
Kyle
It's not that much. I'm pissed I didn't. LME strongly recommended to do it but I said no. I didn't want to have water leaking just driving around. I've now found out that it isn't that bad. Rule #1 LISTEN TO YOUR ENGINE BUILDER!
It really stinks running off the waste gate springs, I would really like to turn up the boost!
Old Sep 13, 2006 | 09:40 AM
  #79
LS1Tech Co-Founder
Maybe I'm wrong, but the engine would be under longer sustained load making a pass versus making a dyno pull on a Dynojet. I would think the load would be very different. On a different note, Purevl, what has your car trapped in the quarter?
Andy have you changed hg's since the last RSD?
Old Sep 13, 2006 | 10:24 AM
  #80
PurEvl's Avatar
havent run it yet, supposed to in oct...however it have gone from 1st gear to 5th gear upto 6800 in all gears on the highway(about 180mph) without any issue more then once. My high temp fan barely comes on half the time. Slowhawk has also ran it on the dyno in 5th to 160 for load tests as well. Never loses a drop of coolant or fills the overflow. But of course im sure one trip at the track it will **** itself because thats my luck
