Anyone know Phillip Bridges? (95 turbo TA)
If you guys look at the 3rd pic you can tell it has a Ws6 Style hood, the other 2 pics are probably somone else's car.
Anyway Badass setup, my buddies seen that car at the pump gas Drags.
I ruin the end of films...
Originally Posted by Brady
pmbmax on this board. Good dude. I rode with him in the '05 PGD's But he broke a tranny cooler fitting and had to bow out that year.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
From what I remember, it's an 88. He had the big turbo sitting in the trailer.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Originally Posted by mongse
I remember that car on Power Tour back in '04 too. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
No idea on the other specifics. I would say the intercooler is custom fabbed. Procharger bypass, large-frame 88, Dart block, drag radials, yadda yadda yadda.
Originally Posted by pmbmax
Yep the car was on the power tour. And thanks for all the good stuff thatyou said, means alot from F body guys that have seen it all. I built headers and all the other stuff that is one off. i am putting a 98 mm on it this week . Thanks Lee for all the help and support at BMR
Can ya break down some things of the build????
Kyle
Thanks for posting, your car is very impressive! What is your best pass with the 88?
1/4 8.78 @160 As for the build up Little M ,AFR 227 ,Victor E , Comp shaft mount rockers ,belt drive,cam, endura X ofset lifters, 7/16 pushrods.The cam is big over .670 lift . dyers rods ,je pistons . 160 lbs injectors weldon 2345 pump and regulator. Msd 7531 ,coil and boost controller. Ptc pg and convertor(all promod stuff) As for the car it was stock when i got it 4 years ago.
Wow nice. You running DFI or a FAST? What was your fastest on pump gas, and your raceweight?
he said 3713 above John......
Thats awsome man........
Bad *** build. Now those 8.6X passes... how much boost were u seeing??
i also want to know what controller.. ie FAST BS3??
Kyle
#32
Originally Posted by T/A KID
I bet its a FAST, being from TN area (comp cams in Memphis,TN) most of everyone runs FAST over in that area.
#33
Kyle
Kyle
#34
At nmca last year it was 3717 with me i will go 220lb and yes it is a sq Fast with all the bells plust data logger.it was at 3605 this year I spent all winter trying to get rid of weight Kerkys stearing colum and wheel plus mini tub. It went 5.80s on a 275 60 at that race.as for boost 15 lbs and at gear change 16 to 17 that is with no line to the gate . and last boost control ,it is a MSD 7562 .
Thansk for the updated info.....
Damn 5.80 1/8's on a 275/60/15.... thats the same tire i run on for the street... gives me hope LOL
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Kyle
