9.6 to 1 compression?
Old Sep 13, 2006 | 10:00 PM
1FST99Z's Avatar
Default 9.6 to 1 compression?
I have been thinking about going supercharger. so I built the car around that. what would be the best supercharger for getting me to 800rwhp@15psi. right now I have a 408 iron setup with a 238/242@115 cam in it. and we should be right around 500rwhp. so now I have seen and I like the procharger units a lot. but also I have started to read up on the Rotex units from W2W. what do you guys think. and maybe even do 2 of the rotex units. hmmm. let me know what you guys think
thanks
Wesley
Old Sep 14, 2006 | 05:43 AM
EPP's Avatar
EPP
The ATI ProChargers are a proven unit. The F1 would make you the power you are looking for. Give me a call at 260 244-4808 for a great price. Bob
Old Sep 14, 2006 | 10:24 AM
99SS-T's Avatar
I know W2W loves thier SC units but i never hear of anyone useing them. They used them on a sleeper they made adn it made SICK power so no doubt they work well.
Most people use the Procharger. Not sure why but that seems to be the norm.
Bob there at EPP is a great guy to get them from. GL with ur build man
John
Old Sep 14, 2006 | 10:47 AM
GrahamHill's Avatar
What color is that?
Old Sep 14, 2006 | 07:41 PM
1FST99Z's Avatar
arrival blue, Bob I will be calling you in the morning somtime, and also I will probably looking into more information on the rotax stuff as well.
Old Sep 15, 2006 | 05:12 AM
EPP's Avatar
EPP
Thumbs up
Cool, give me a call. 260 244-4808. Thanks! Bob
Old Sep 15, 2006 | 06:40 AM
Slowhawk's Avatar
LS1Tech Sponsor
F1 will work good.I'll be testing a D1 on a 427ci today.Should hit 800+rwhp,but we'll see.
Old Sep 15, 2006 | 06:49 AM
1FST99Z's Avatar
wow that is a lot of power.
Old Sep 15, 2006 | 07:31 AM
Got Me SOM's Avatar
You may want to switch cams to something with a smaller duration for more area under the curve unless you are just a drag racer.
Old Sep 15, 2006 | 12:16 PM
2000 Tran Zam's Avatar
Not only that, but I would look into different heads or pistons cause unless your running dished pistons for FI your gonna blow some **** up from too high of compression.
Old Sep 15, 2006 | 02:15 PM
1FST99Z's Avatar
as for the cam, I may be wrong on the numbers. it is comps blower cam. and the heads are afr225's, and the pistons are JE's boost pistons.
Old Sep 15, 2006 | 02:17 PM
1FST99Z's Avatar
also I would be happy with running 12lbs and 7XX rwhp as well.
Old Sep 15, 2006 | 03:56 PM
C.W.A's Avatar
I'm using the procharger D1SC and had great results! 600rwhp 497rwtq on a stockblock LS1 with heads and cam! The 600rwhp was at 6psi I could have made more ,but the stock bottom end would fall apart!
Old Sep 15, 2006 | 05:43 PM
1FST99Z's Avatar
great info. thanks. and sweet ride.
