procharger help
Old Sep 22, 2006 | 07:00 PM
my01ws6's Avatar
Default procharger help
I came across a used procharger set up its the p1sc it doesnt include the horn or air pump relocation brackets, or optional FMU, and the crankshaft damper bolt came loose and the balancer pulley came loose, also the plastic airbox is broke where the clamp goes around it. it does have a heavy duty trutech mounting bracket and everything else.
The guy wants $1700 for it...is it a good deal? What all would i have to buy to get this thing running good?
Also what kind of RWHP am i looking at?
Old Sep 22, 2006 | 08:11 PM
my01ws6's Avatar
anyone?
Old Sep 22, 2006 | 09:26 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Buy it.
Old Sep 22, 2006 | 09:38 PM
my01ws6's Avatar
what all do i need to buy to get it working right?
Old Sep 22, 2006 | 11:46 PM
Get with Bob @EPP. He will give you the best price and answer your qs.
Old Sep 22, 2006 | 11:52 PM
my01ws6's Avatar
im not even sure what i need to be buying tho...
Old Sep 23, 2006 | 03:08 AM
BOONE's Avatar
Bob is and he wont take advantage of you.
Old Sep 23, 2006 | 03:32 AM
618HAWK's Avatar
Bought my setup in pieces as well, got the rest through BOB@ EPP. Saved a bunch. You can get a way with out the horn and airpump relocation kits.
You dont need the FMU! Will need new injectors, and a good tunner!
Off to a good strat with the better bracket.
Better off to replace the plastic airbox and go with alum.
Sounds like a 6 rib will need to upgrade to a 8rib.
Old Sep 23, 2006 | 12:48 PM
EPP's Avatar
EPP
Thanks everyone, I appreciate it! The horn bracket and air pump relocation brackets aren't that vital, as has been mentioned, you can make do without them. We may even have a couple left over from builds on our shelves. I also suggest not using an FMU, but install a larger Walbro 255 hp in tank fuel pump, pick up some 42lb fuel injectors, and get a dyno tune. The 42 lb fuel injectors can be found used easy enough these days, as many are upgrading to 60lb injectors as they escalate the power level of their engines. I can get you the new crank bolt, and anything else you need. On the six rib kit, normally when the crank bolt comes loose, the three little pins on the ProCharger crank pulley bend, but usually the pulley is fine other than that.
Its a good price, provided nothing is wrong with the head unit. Bob
