Dyno 402 T76GTQ ### in
Old Oct 23, 2006 | 12:24 PM
RealQuick's Avatar
Originally Posted by NA$TY-TA
I dont doubt the GT42-76 w/ a T6 falnge will out flow that 76... i had one with a T6 flange and she was out of steam by 14 psi... im jost posting up my .02..... we will see as time goes along with the STS 76's on a 408....
Kyle
I still like you I wasnt questioning whether your right aout the 76... just mentioning that rear versus front MIGHT not yield the same results. FYI... I sold my GT42 (same as yours) and will be going 88mm for my 383 LTx
Old Oct 23, 2006 | 01:21 PM
obZidian's Avatar
get a backpressure reading on that setup.
Also, has anyone ever heard of a a similar t76 with a t6 turbine housing? Worth a try, i guess, if your set with that turbo.
I agree though, the compression maps suggests that the turbo used for this app. is to small. A t88 with a t6 will be a good match. If anything, please get a backpressure reading so we can see what is happening infront of that turbo.
LAterZ!
Old Oct 23, 2006 | 01:32 PM
DrTurbo's Avatar
LS1TECH Sponsor
The S76 is T6 and has a big turbine side. Probably the highest flowing 76mm unit I know of.
Old Oct 23, 2006 | 01:58 PM
obZidian's Avatar
ok, now that i got your attention... what is the basic difference, in actual application and productivity (how it runs) a S82 compared to the S88?
That S76 seems like another good solid match for this app. as well. What AR's is it available in? Also, the S82, what ar's can you get tha turbo with?
Old Oct 23, 2006 | 02:09 PM
DrTurbo's Avatar
LS1TECH Sponsor
The A/R's available are 1.1 and 1.3A/R's. The units are all based on the same chassis and will produce big power. As for 82 vs 88, well the 82 is a trimmed down wheel we do on the CNC machine. Its essentially an 88mm wheel CNC cut down.
Old Oct 23, 2006 | 06:21 PM
Frost's Avatar
Originally Posted by obZidian
That S76 seems like another good solid match for this app. as well. ....
No.
Kyle already mentioned in this thread the ineffeciency of this unit on his 370.
Old Oct 23, 2006 | 07:59 PM
DrTurbo's Avatar
LS1TECH Sponsor
The S76 is a much larger 76mm unit. Also it has the ETT wheels which will move ALOT more air per mm of wheel.
Old Oct 23, 2006 | 08:40 PM
02SSLE's Avatar
I am going to do back preasure test this weekend before turbo and before and after intercooler. The thing is I had the opertunity to build a 402 for the same price as 370. What would you have done. I did what I wanted and built the 402. I won't have to turn the engine as hard with this setup to make the same power and more.
02SSLE's Avatar
Leo post my Dyno Sheet.
Old Oct 23, 2006 | 08:45 PM
02SSLE's Avatar
The cool thing is it makes sick low end power. Instant tire shreader. I am thinking of doing a 88 of some sort but not for sure yet. I will probally enjoy what I have for now. Also the funny thing is this is still on stock rear LOL. Early Spring I will order one for it. What plugs are you guys running?
Old Oct 24, 2006 | 06:05 AM
NA$TY-TA's Avatar
Im running TR6's..... Yeah i might have done a 408.... depends on what parts are in it..... ill tel you one thing..... ill be going back to aluminum sooner or later...... this extra 90lbs on the nose is hurting me.....
If i ever do a 408 it will be with a 88/98 at least or a 94mm....
Have fun driving it.... thats what im doing to mine.... it loves these 40-55 degree days.
Kyle
Old Oct 24, 2006 | 06:09 AM
  #32
02SSLE's Avatar
I read in my GM performance book that there is only 30 pounds difference between the Alum and the iron.
Old Oct 24, 2006 | 08:14 AM
  #33
NA$TY-TA's Avatar
hah ah ah ah LOL i guess they never took one and wieghed it.. LOL
ive had both...... 30lbs wont make the front sag like an iron block will..... the 1st time i got an iron block i had to get rid of my prokit springs.... she sat wayyy to low.....
Old Oct 24, 2006 | 09:58 AM
  #34
marcus769's Avatar
Good info guys, keep it comin!
Old Oct 24, 2006 | 10:18 AM
  #35
parish8's Avatar
single digit dreamer
i had the cmotorsports single kit with a t76 q trim on it running on a 408. it maxed out at exactly the same hp and tq. this was thru a 4l80e and tcase.
here is the exhaust manifold it had on it. along with a 3" dp
next we steped up to a "race" header and a 3.5" dp. here is a pic of that.
guess what. exact same dyno numbers. i would have thought the down pipe at least would have helped some but it didn't so to me that says the turbo itself was maxed and not the turbo set up.
last mod was to swap a pt88 with a t4 flange. it bolted right in place of the t76 on the hot side but i had to redo the cold side. wamo, 1000rwhp. i am sure the "race" header set up is better than the first set up i had but from those tests i dont think the first header was maxed out yet. it would have been neat to see what the 88 could have done on that first header and a tiny 3" dp. i bet it would still hit 900+rwhp
Old Oct 24, 2006 | 11:44 AM
  #36
SSblack98's Avatar
So are all the S-series turbos only available in T6 flanges? If so I guess that is where they get all the extra flow. Thinking about a S78 for my 364ci setup with OFI kit. I guess I would require a T6 then...
Old Oct 24, 2006 | 11:56 AM
  #37
engineermike's Avatar
I wish you guys would try replacing the Q-trim with an S-trim exhaust wheel. I'm starting to thing the little Q-trim wheel just doesn't produce enough power to spin the 76mm compressor to it's potential.
Old Oct 24, 2006 | 12:17 PM
  #38
DrTurbo's Avatar
LS1TECH Sponsor
Yeah the S series is T6 though and it will make BIG power.
Old Oct 24, 2006 | 12:25 PM
  #39
RealQuick's Avatar
Originally Posted by TURBO383WS6
ok, you guys have definately got me worried now. i've got a 9.1:1 compression 383 LT1 w/ a PT76GTS. am i going to run into the same problems w/ maxing this out? if so, is there another T4 flanged turbo that i can step up to and keep most of the same hot and cold side piping to remedy the situation? i haven't had a chance yet to really get on this car, but what little i have played with has been pretty impressive for the ultra safe tune that's in it.
You will be limited... but 700rwhp should be achievable. Just know that smaller cubes (like a 355ci) with your same turbo will most likely make more power than you.
Old Oct 24, 2006 | 12:26 PM
  #40
TURBO383WS6's Avatar
