Dyno 402 T76GTQ ### in
Old Oct 24, 2006 | 01:26 PM
  #41
SSblack98's Avatar
Originally Posted by DrTurbo
Yeah the S series is T6 though and it will make BIG power.
What kind of increased lag is there with say a S76 over a T76?
I don't want the lag of a T88 sized turbo but I want more flow/power potential then a T76.
Old Oct 24, 2006 | 01:41 PM
  #42
DrTurbo's Avatar
LS1TECH Sponsor
An S76 will spool around 3600-3800 of course alot depends on the compression, cam, head flow...etc..etc.
Old Oct 24, 2006 | 01:48 PM
  #43
SSblack98's Avatar
The comp ratio is 8.5:1, handfinished AFR 225 heads, LS1speed turbo cam---
225/225, 581/581, 113lsa. Looking for 700rwhp pump, 800+rwhp race gas.
Would you prefer the S76 or S78 for this setup...
Thanks for your input by the way and sorry to jack the thread kinda.
Old Oct 24, 2006 | 02:41 PM
  #44
DrTurbo's Avatar
LS1TECH Sponsor
I would go with the S76 for that. Spool nicely and make big power with that setup. I don't see 800rwhp being a problem.
Old Oct 24, 2006 | 06:44 PM
  #45
SSblack98's Avatar
Thanks alot for your help...I will likely be calling you guys soon to order one.
Old Oct 24, 2006 | 07:18 PM
  #46
engineermike's Avatar
Originally Posted by TURBO383WS6
ok, you guys have definately got me worried now. i've got a 9.1:1 compression 383 LT1 w/ a PT76GTS.
You don't have anything to worry about. If the T76GTS can make 990 rwhp with 355 cid, I really doubt an extra 28 cid is going to reduce the capability much. Also note that they're talking about the smaller Q-trim exhaust (900 hp limit) as opposed to your S-trim (1100+ hp limit).
Mike
Old Oct 24, 2006 | 08:48 PM
  #47
Stupid Boost's Avatar
I wonder how a Q-trim vs a GTQ would be?? I hear that the GTQ flows much better and then the standard Q, plus also T-netics has a new turbine wheel that is suppose to be between the GTQ and GTS turbine wheel, wonder how that wheel does.
Old Oct 24, 2006 | 09:02 PM
  #48
Why not just go straight to the GTS?
Old Oct 24, 2006 | 09:32 PM
  #49
02SSLE's Avatar
Well tonight was the first time I really got in the car hard with new setup. Man it pulls really hard. I took one of my friends for a ride. He has a turbo Hybussa making 500 hp to ground he was very impressed. Only got on it threw 3rd gear. I am planning on taking it to the track this weekend. I still have factory 10 bolt so it's going to be street tires for me. We only have 1000 ft track here but I am expecting close to 120 mph. I am thinking of going with some sort of 88 turbo but not sure which one.
Old Oct 24, 2006 | 10:17 PM
  #50
Frost's Avatar
+1...
Old Oct 25, 2006 | 08:31 AM
  #51
RealQuick's Avatar
Mike
The quoted numbers I believe were 950rwhp @ 24psi, but nobody has come close to that # on any of the boards (LSX or LTX), so we should be careful by throwing around the big numbers (so people dont feel let down when they dont come close). The Q trim is rated for 975fwhp versus the GTS 1100fwhp.
Mike, you should see if yould could squeeze a T4 T88 into your kit (probably need some minor rework)... I bet you could see +150rwhp over what you make now.
Old Oct 25, 2006 | 12:25 PM
  #52
He actually made 987 rwhp with the wastegate blocked off and reportedly 24 psi. He switched to a T88 and it only made 1012 rwhp at a similar boost level.
Absolutely no way with my layout. The T76GTS is crammed in there with only 1/2" clearance around the exhaust housing. I'm considering upgrading to the T80GTS since it's the same external dimensions, though.
Old Oct 25, 2006 | 12:49 PM
  #53
DrTurbo's Avatar
LS1TECH Sponsor
Yes that LT1 made 987rwhp peak, but could not hold it. It would spike up then drop off. So realistically it probably was making low 900's-high 800's as an average. Also running a turbo without a wastegate is not the best thing for it if your thinking longevity.....lol
Old Oct 25, 2006 | 12:50 PM
  #54
DrTurbo's Avatar
LS1TECH Sponsor
Also MM made over 900rwhp out of a Turbonetics 76 on his setup I believe. So it has been done....just most people won't push their cars that hard.
Old Oct 25, 2006 | 03:53 PM
  #55
Frost's Avatar
Think he made 85X on that one....
Old Oct 25, 2006 | 04:09 PM
  #56
bboyferal's Avatar
My 76GTQ, according to compressor maps, will be high up there in the efficiency range at 14,15 psi... Just right for me for maximum spool/powerband. But I have 346 cubes... I can't imagine how hard the turbo would be pushed with EVEN MORE displacement. Just my $0.02
For that displacement, it should've have been AT LEAST a 76GTS (will flow more). Can something bigger fit on that kit?
76GTS is ideal on a 346 on pump (~15psi), with a little room for a race gas tune (15 psi+). My 76GTQ will be no good for race gas/high boost over 15 psi on 346 cubes. Yours is on a 402. That turbo MIGHT be getting choked, but I am not an expert. Good luck man. 600+ rwhp is 600 rwhp+ Sounds good for now, especially on the stock 10-bolt.
Old Oct 25, 2006 | 07:04 PM
  #57
02SSLE's Avatar
My old motor was forged 347 and it 18 psi of boost on it. Yes I can put bigger turbo on this setup. Just need to modify the frame rail for clearance. With current setup there is no lagg. Spools very quickly.
Old Oct 25, 2006 | 08:04 PM
  #58
02SSLE's Avatar
Dr Turbo what kind of back preasure issues would I have with the S88?
Old Oct 25, 2006 | 08:07 PM
  #59
02SSLE's Avatar
What kind of exhaust preasure should I find before the turbo? I am going to check it this weekend.
Old Oct 25, 2006 | 09:17 PM
  #60
With a T76GTS and short 3.5" downpipe on 377 cid, we got 26 psi backpressure at 18 psi boost. On my T76GTS and 3" downpipe with a muffler on 383 cid, I got 34 psi backpressure at 18 psi. With the wrong muffler, I had as much as 48 psi backpressure at 18 psi.
Mike
