F1-A or F1-R
Old Nov 8, 2006 | 11:18 AM
  #61
GrannySShifting's Avatar
I liek the F1A or F1C Feher if you want to keep the rpm down. F1R, Im going to try and talk you into some good lifters and turning 7300 rpm. We do it all day
Old Nov 8, 2006 | 11:21 AM
  #62
LSs1Power's Avatar
The only way i would go with F1-A is the clearance we can have between the radiator and the head unit. The F1-R or C will be a tight fit and we will most likely have to cut the front brace of the car and make it thinner or add another alum bar to strengthen the car regidity.
Old Nov 8, 2006 | 11:28 AM
  #63
OK then, F1R and 7200 sounds good to me, wont have to run a small blower pully so it holds the belt better
Old Nov 8, 2006 | 11:58 AM
  #64
kp's Avatar
kp
I decided to try an F1A, since all I have to do is bolt it on we'll see what happens as soon as it gets here
Old Nov 8, 2006 | 12:36 PM
  #65
ty_ty13's Avatar
7 Second Club
wahoo! when will the runs begin?
Old Nov 8, 2006 | 12:37 PM
  #66
onfire's Avatar
Coal Mining Director
You need an F4
Save ya from selling the F1A next year.
Old Nov 8, 2006 | 12:52 PM
  #67
kp's Avatar
kp
Na, 8.99 and I'll be happy Tom
ty_ty, whenever it gets here..
Old Nov 8, 2006 | 01:00 PM
  #68
ty_ty13's Avatar
7 Second Club
what size pulley will you run?
Old Nov 8, 2006 | 01:20 PM
  #69
kp's Avatar
kp
7.25/4.1 to start, biggest I have..
Old Nov 8, 2006 | 03:28 PM
  #70
LSs1Power's Avatar
Great news... Plase keep us posted.
Old Nov 8, 2006 | 03:53 PM
  #71
LSs1Power's Avatar
Jeff,
According to my calculations... The F1-R would be running at 70000 impeller RPM with a 7.25 crank and 3.8 SC pulley at 6800RPM. That doesn't sound bad at all. Im sure we will see 17-19psi with that pulley.
If no one bought the D-1SC we will most likely take it to 7000 RPM with 3.4 pulley
Old Nov 8, 2006 | 04:05 PM
  #72
CHRISPY's Avatar
Awesome info guys. If I go blower I'll go F1A and front mount right from the start.
What pulley setup on a 346 will yield about 10#'s boost at 6300rpm with the F1A?
Old Nov 8, 2006 | 04:09 PM
  #73
LSs1Power's Avatar
If you run the 7.25-7.65 crank I would guess 4.40-4.60. Just a guess for now though.
Old Nov 8, 2006 | 06:08 PM
  #74
eb02z06's Avatar
Do you think it's possible to run a 6 rib with a F1C or F1A? The gear casing looks so much bigger-just wondering if it's any harder to drive than a D1SC?
Old Nov 8, 2006 | 06:20 PM
  #75
andereck's Avatar
Its been done on C5-6's with the StageII bracket but isn't recommended. Its going to slip when driven hard. (it can slip on the crank pulley too as one belt drives everything on the Vette)
8 rib or better is a must. They both move substantiaaly more air than a maxed D1SC and the lower ratio transmission places a higher load on the drive.
Old Nov 8, 2006 | 07:58 PM
  #76
CHRISPY's Avatar
Thanks man
Old Nov 9, 2006 | 05:02 AM
  #77
EPP's Avatar
EPP
http://www.exoticperformanceplus.com...Car.php?car=40
We used the eight rib on this C5, along with the ECS balancer/crank pulley, which is larger in diameter. The larger diameter of the lower pulley really helped us out with belt slippage. Andereck is correct, as always... You have to use the eight rib. Bob
Old Nov 9, 2006 | 10:06 AM
  #78
eb02z06's Avatar
So Bob the procharger 8 rib upgrade doesn't include the crank pulley?
Old Nov 9, 2006 | 10:45 AM
  #79
andereck's Avatar
On a Corvette the balancer is the drive system, so you need an aftermarket balancer such as the ATI Performance Products balancer with 8 grooves.
Old Nov 10, 2006 | 09:19 AM
  #80
E.A.'s Avatar
Not on the F-body cars or the Corvettes.
When making the 8 rib upgrade.....
#1) From your ProCharger dealer, you need to get the 8 rib upgrade kit(s)
#2) As well as a ATI Performance Products Balancer.
The parts from ATI ProCharger include the new Blower Crank pulley, Blower pulley, belt, idler, and hardware and spacers.
The new Crank pulley will only bolt up to an aftermarket balancer. (An ATI performance parts unit)
Reason for that is, better mounting surface, and the new balancers have better hubs in them to take the power that is going to be needed to turn blowers that are going to require 8 rib belts. Plus if you are making that much power, you might as well have a good balancer on the car anyways.
EA
PS: On the Corvettes you need a true 8 rib balancer. BUT, on a F-body car, you are just getting a 6 rib factory replacement unit. Since the F-bodys run a dedicated crank pulley that mounts to them.
