F1-A or F1-R
Old Nov 10, 2006 | 09:57 AM
  #81
eb02z06's Avatar
E.A. glad to see you here-hopefully it will be lot more civil here toward the Prochargers than over at the CF forum. Okay-I'm getting a bit confused now. Your saying that the Procharger 8 rib upgrade has the blower crank pulley, blower pulley and tensioners. Your saying that the blower crank pulley bolts up to the ATI hub? What is the part # for the ATI hub with the ac pulley that is needed for this? Also what is the diameter of the crank pulley? Last I saw the ATI unit was only 7" in the 8 rib version-I don't understand why anyone would want to go smaller than that?
Old Nov 10, 2006 | 11:11 AM
  #82
E.A.'s Avatar
Corvettes: The Blower system runs on the same belt as all the accesories
F-Bodys: The Blower runs a dedicated drive. Just for the blower.
When you upgrade to the 8 rib system on the Corvettes.
You get new.....
spacers for the brackets,
new idlers,
p/s pulley,
alternator pulley,
blower pulley,
But you still have to get the 8 rib ATI Perf. Products Balancer from another vendor. Since ProCharger doesn't stock them. This is what is going to run the supercharger. It's the same diameter as stock, just wider.
Balancer Part Number #917345
When you upgrade to an 8 Rib for a F-body
Since they run a dedicated Drive that bolts to the balancer.
You get a new....
crank pulley, (7.65")
new idler,
spacers,
blower pulley.
But you will have to buy a 6 Rib ATI Perf. Products Balancer from another outside vendor, being as though once again, ProCharger doesn't stock them. The part has NO bearing on boost level, being as though it's not turning the supercharger. It is mearly a better mounting surface for the ProCharger crank pulley.
Balancer Part Number #917242
Yes, you have to buy a new balancer even though the Crank pulley is bolting to it. Reasons are simple as to why.......
1) Machined mounting surface
2) Stronger Hub in the balancer it's self.
3) High HP motors, should have this part on them anyways. your taking chances running the stock stuff.
Hope this helps,
EA
PS: You also have to get the ATI Perf Products Balancer Pinning Kit. Since it is different then the ProCharger Pinning kit. I believe, don't quote me on this, but I think the part number is PN# 918993
Old Nov 10, 2006 | 04:06 PM
  #83
dementia's Avatar
Are there pulley combos that would allow the F1 or F1A to run low boost say 7-8 psi?
Old Nov 10, 2006 | 07:52 PM
  #84
Ponyhntr's Avatar
Most likely not... you won't be able to get a large enough pulley to slow it down enough... they flow a BUNCH of air! On my stock shortblock LT1, I have my D1SC turning as slow as possible (7" crank with a 4.5" blower), and it still makes about 7 psi on cold days... at 6200. An F1/A would be about 4-5 psi higher!!
Old Nov 10, 2006 | 10:36 PM
  #85
KissMySSo1's Avatar
buy a turbo
Old Nov 11, 2006 | 06:02 AM
  #86
EPP's Avatar
EPP
Question
If you installed a cam with a lot of overlap, you could bleed some boost off. If you're planning on putting the larger blower on a stock bottom end, you could always short shift it for now. I guarantee you that short shifting will get boring real quick though... Bob
Old Nov 11, 2006 | 06:37 AM
  #87
CHRISPY's Avatar
hehe put a wastegate in with a 9# spring. It'll blow off the extra boost when it hits. You might hit 9#s at 4000rpm and hold it to redline
Old Nov 11, 2006 | 08:12 AM
  #88
MyWs62FaST4u's Avatar
hey bob, or andereck... would that F1c be ok to use 4 or 5 days out of the week? to work and back, and maybe cruising thereafter???
Old Nov 11, 2006 | 09:31 AM
  #89
andereck's Avatar
Yes, if you like noise. With the bypass it will sound like a circular saw.
Old Nov 11, 2006 | 09:49 AM
  #90
kp's Avatar
kp
You can also use a restrictor on the inlet to keep the boost down. If there is less air to compress it wont heat up as quick as doing a wastegate type thing I wouldnt think.
Old Nov 11, 2006 | 10:41 AM
  #91
when you say "yes"... you mean it wont be overkill on the street? like say it hits 90 degrees, in the summer, i'd need an a2w-instead of an a2a? is there any real big issues with driving that kind of power on regular trips?
Old Nov 11, 2006 | 10:49 AM
  #92
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd pick the blower that fits the stock brackets and let's you run a decent size filter. I think the guys looking at running custom size blowers are glossing over all the changes they need to make. And wait till you try making over 20psi, you'll need a strut brace.
Old Nov 11, 2006 | 11:05 AM
  #93
can we have a sample??? lol...
Old Nov 11, 2006 | 11:08 AM
  #94
andereck's Avatar
I have a friend who drives an F1C equipped 4.6 Cobra daily as basic transportation without issue. Of course it has a race bypass which is required with that kind of airflow, escpecially on a small engine.
Old Nov 11, 2006 | 11:51 AM
  #95
kp's Avatar
kp
I have to agree here, I was tempted to do the F1C but I'm not sure my drive will handle it and having a bigger inlet is going to be a hassle with the filter on these cars. It may be more expensive to go a step up at a time but in the FI world spending 1000-1500 to sell you smaller blower and get a bigger one is small change overall.
Old Nov 11, 2006 | 01:06 PM
  #96
well beside the little 281, how about that same blower on a 408?
Old Nov 11, 2006 | 01:36 PM
  #97
andereck's Avatar
You still need a race bypass. Street driving is not going to hurt the blower. I'm pretty sure there is a video on here of a Camaro with either the F1C or F1R street driving. I seem to remember a night shot or something. Maybe he can weigh in on his experiences with it.
Old Nov 11, 2006 | 03:57 PM
  #98
ok, thanks guys
Old Nov 11, 2006 | 05:27 PM
  #99
Ponyhntr's Avatar
OT: MARK!!! GET OFF THE INTERNET AND GET YOUR PROJECTS DONE!!!
Old Nov 12, 2006 | 03:24 PM
  #100
andereck's Avatar
Thanks Josh, that's going to be part of my signature...lol.
