garrett 83mm t6 turbo+370ci=what
im having a 370 ci iron block built with dart heads ls6 intake i just purchased a 83 mm turbo,
Compressor Wheel Inducer ( mm ) - 83mm
Compressor Wheel Exducer ( mm ) - 101mm
Turbine Wheel Inducer ( mm ) - 101mm
Turbine Wheel Exducer ( mm ) - 91mm
Turbine Inlet Flange - T-6
Turbine Housing Outlet - 5 Inch V-Band
Turbine Housing A/R - 1.23
with the right fuel system n all the other odds n ends should i be able to hit 1000hp at the wheels? its not gonna see much street use mainly track 90%. I also get a a/r .96 turbine housing too
Originally Posted by wickedred
I don't see hitting 1000hp being a problem at all. That turbo is more than capable of supporting the power. Good lucj and keep us posted on the numbers.
well i backed out the deal with the turbo the seller only will take a money order and i also found out he sold some bad turbos so im back looking again.
Originally Posted by F8LWS6
I was looking at that same turbo on ebay. Saw about the bad turbos and he wouldn't answer my questions.
Originally Posted by bumpin_records
Im looking for something that will give me 1000+hp at the rear wheels john
I'd run a T6 flanged turbo to avoid major back pressure at the turbo.
LS1Tech Co-Founder
Unless you are trying to fit a class, I think you should go for running twin 66/67 mm turbos. I think a combo like that would hit 1000rwhp all day long and you would not deal with lag issues or the packaging issue of stuffing an 88-94mm turbo into the front of your car.
Go with an S85, that will make 1000rwhp and its T6 flanged. Or go with a PT88 which will make a less power, but its on a T4 flange and also the compressor side is smaller, but still makes great power.
