The numbers are in: 576 rwhp @ 4.5 psi SAE
Old 10-30-2006, 04:12 PM
SS00Blue's Avatar
Great numbers! It does seem like they are high for the combo. Even with the super special cam. It's hard to imagine a cam that no one has ever ground could produce 100+ more hp than any other combo on a Mustang dyno.
Larger turbos don't necessarily make more power at lower boost. The key is to relieve intake tract restriction, which by your own statement is limited to a set of stock 317s. Hardly a significant modification. Larger turbos have greater potential to flow more air IF the intake restriction is also addressed, otherwise they just delay full boost.
All scepticism aside, please put it to the track and put us doubters to shame .
At 576rwhp and ~3400lb weight I can't imagine anything less than 140+mph.
I hope that's where you're at on the track, otherwise it's going to be in question.
SC-
Old 10-30-2006, 04:20 PM
Willem @ Fuel Injection Concepts's Avatar
i dont see a ~600 rwhp car going 140+ in the traps unless its a gutted miata
Old 10-30-2006, 04:52 PM
sr71's Avatar
big cam and big ar's shift the powerband up and make it come in more gradual like a centrifugal sc. and they make big power.
Old 10-30-2006, 05:30 PM
Got Me SOM's Avatar
hmmmm
Old 10-30-2006, 06:14 PM
SS00Blue's Avatar
The car I built and raced:
1982 Mustang GT, 3400lbs w/driver, full interior, Skinny Kid 10-pt, 4.10:1 gear, T-5, 347/Streetheat heads w/2.055 and 1.600, 12:1, Sonny Bryant, Crower, Wiesco, 455rwhp on a DynoJet... 10.31 at 131mph on first Gen BF Goodrich DRs.
That's documented in 1998.
If you have 576rwhp on a MUSTANG dyno, no less, I don't see 140 being even the slightest problem. SMOKEMUP.com seems to bear this out.
I'm not trying to argue on the bench, but the track shall set you free. Please show the ney-sayers wrong. I'd be happy to apologize.
SC-
Old 10-30-2006, 06:38 PM
KissMySSo1's Avatar
i call on those numbers at 4.5psi.
speed inc built a car with twin GT35R's and it didnt make that power at almost 3 times the boost.
i know of a car (98 camaro) went 10.20 @ 138mph with 550rwhp
Old 10-30-2006, 07:01 PM
SS00Blue's Avatar
OBTW, I've been at Detroit Dragway (dating myself) where 550fwhp BBCs have run mid-130s in 3500lb 2nd gen Camaros, many, many times. It doesn't take 576rwhp (Mustang Dyno) to run a 140. In a full dressed Caddy even.
SC-
Old 10-30-2006, 07:09 PM
andereck's Avatar
SC-
Well, it sure helps.
Old 10-30-2006, 07:13 PM
CorvetteCaddie's Avatar
Good numbers!
Too many doubters out there.....IMHO
I have a feeling that a high reving engine with the right cam could show that kind of HP especially with those free flowing GT35s!
Look forward to seeing the dyno chart
Old 10-30-2006, 07:27 PM
sorry, i forgot Speed Inc = The Authority on Power
Old 10-30-2006, 07:35 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Dyno sheet?
Old 10-30-2006, 07:52 PM
  #32
Bad30th's Avatar
+1 to see the dyno sheet. ...are you sure the boost reading was accurate ?
Rob (Bad30th)
Old 10-30-2006, 09:00 PM
  #33
Restricted User
NOSjohn's Avatar
Twin GT35 - what ? There are more than 12 configurations for that turbo, including the GT35-82R. What cover - E cover, S cover or SP cover? What is the trim on the turbine cover? If it was the latter (GT35-82), with a .63 or .82 housing, I would easily believe it.
Some specifications on the turbo may help. Good numbers, if a graph can be provided.
Old 10-30-2006, 09:35 PM
  #34
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,162 Likes on 756 Posts
Was Larry there when you dynoed Bill? I have no problem believing Bill, I bet he's running some big traditional split cam.
Old 10-30-2006, 09:47 PM
  #35
JV was there
Old 10-30-2006, 09:49 PM
  #36
I'm not giving out any specs, I dont care if people need to do their own "calculations" if they dont believe me or whatever. Classic bench racing. I'll post up the dyno slip when i scan it and thats it. Personally I care about how much power I made almost as much as I care about what shade of brown my **** is.
Old 10-30-2006, 10:43 PM
  #37
Moderator
FANTAZ28's Avatar
no your right they are a bunch of idiots over there!
i mean those idots over there seem to have built the fastest turbo ls1's in chicago! but whta do they know.......
p.s. i got a stock 346 with a camshaft if you want to try your luck before track closes
Old 10-30-2006, 10:49 PM
  #38
andereck's Avatar
Then why did you start a thread on it?
Old 10-30-2006, 11:15 PM
  #39
JPMuscle's Avatar
Originally Posted by Turbo LS1 SS
bill ur comin over to buffalo in the spring for a bbq/cruise day..... no if ands or butts. in fact, anybody in the area come once i organize it
Sounds like a fun time.. I here jason short is living up in Rochester now, i havnt talked to him in a few months. That would be sweet to meet back up with some of the old FLFB guys.
oh and TT there chicken wings (drooling on my self with hunger) at least they are everywhere south of buffalo where im at.
-john
  #40
i didnt mean to put down speed inc in any way, I just meant how dude was referring to what they did like it was the gospel and SP should have their dyno fixed because speed inc didnt make those numbers before and its written in stone.
Quick Reply: The numbers are in: 576 rwhp @ 4.5 psi SAE
