408ci Twin 67mm preliminary dyno results...
#43
SSU Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Actually in the 60's/70's they used clutches in auto's and called it like a "Poor man's Lenco" or some ****. Don't know what they did or how they did it. Just heard it from a dude.
Anyway, have you been on the dyno yet (today)?
#45
Moderator
Originally Posted by Jon @ Speed Inc
*cough* ....
878 on 12psi
1162 on 23psi Running pretty rich
(yes Haider, boost gauges go above 20)
Thats all for today on the dyno
878 on 12psi
![Icon Twisted](https://ls1tech.com/forums/images/smilies2/icon_twisted.gif)
did you have to run more than one gauge to get it to read above 20?
#48
Jim dont you know you are supposed to switch to BARs when talking about boost over 20#. You have to start speaking ricer. For instance, I ask, "how much boost are you running". Supra owner replies, "3BAR."
GAME OVER!?!?!?
GAME OVER!?!?!?
#54
Looks like a LS2/90mm combo on the car now.
#56
Originally Posted by CP05GMC
Why ditch the carb intake and 90mm NW TB that was on there on the first set of pics for the LS6 and Accufab 78mm?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
but, Jim can chime in for the reasoning behind the swap
#57
Originally Posted by INTMD8
Engine is our extreme 408 with AFR 225 heads, LS6 intake manifold, accufab 78mm throttle body, BS3 engine management, 96lb/hr injectors, twin bosch fuel pumps.
#60
Thanks guys, I'm rather pleased with the results. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I bolted up a set of 17in et street radials for todays dyno session. I don't think they were spinning much but they were pretty balled up after the runs.
The intake manifold was changed to the LS6 because I dislike the short turn "radius" of the fabricated elbow that must be used for clearance with the stock hood.
