Somethings wrong with the car... (video inside)
Old Nov 27, 2006 | 01:07 PM
  #41
GrahamHill's Avatar
Originally Posted by Inspector12
With that few of miles on it I don't know what you were thinking getting on it you should have put a few miles on it before beating on her so with that said you could still have a motor problem sorry hope not.
3,000?? How long do you wait?
Old Nov 27, 2006 | 01:31 PM
  #42
obZidian's Avatar
dude, this sucks!
Any luck with the first string of tests? It could be a number of things but one thing for sure is that i wouldn't be sane after a build like that and it going south... especially with some other guy riding it!!! ( i know its cool but still... )
Old Nov 27, 2006 | 01:41 PM
  #43
2000 Tran Zam's Avatar
Originally Posted by obZidian
dude, this sucks!
Well theres no reason getting all upset over it, only makes things worse.
Whatever the issue is I'll have to pay to get it fixed... and then I think im out of the game.
Every ******* time I have the car up and running strong it runs for a few days before something else breaks.
I can afford to keep dumping money into it as fun as it is, its not worth it.
Old Nov 27, 2006 | 01:48 PM
  #44
I would assume he's talking about the clutch, but I would think that 300-400+ street miles would be enough before you start to even get into boost...
Old Nov 27, 2006 | 01:50 PM
  #45
Originally Posted by Tiago
I would pull the plugs and check for damage, then checck the oil.
When I check for damage on the plugs, what am i looking for?
Am I gonna be looking for plugs to have the porcelain part broken off, or completely white from a lean situation?
Old Nov 27, 2006 | 01:52 PM
  #46
Originally Posted by 2000 Tran Zam
OK, heres the vid..
http://videos.streetfire.net/video/a...840114a6b2.htm
Does anyone have any clue what it it?
We were driving about a 130 or so when the car shut off. we coasted it into a parking lot and the battery was pretty much dead.
So I towed it home and recharged the battery.
Now it makes this horrific griding noise when I start it. The first time it did it it started, made the noise and the motor shut off on its own.
The second time i did it to get video, it started and didnt shut off so after a second and a half i killed it cause I didnt want to continue to hear that noise.
Anyone have any clue what it is?
I was thinking maybe the flywheel is bent, I sure hope to god its nothing with the motor.
But on a side note, I know my car was making a **** load of power.
4th gear, 120mph, 315 bfg drag radials, pump gas, tires spinning like crazy
Old Nov 27, 2006 | 02:00 PM
  #47
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You are checking your oil to see if the oil looks like it's mixed with coolant, and become a milkshake. You would also look for metallic glitter which would indicate that you have bearing material in your oil.
You are pulling your plugs to see if if the tips are undamaged, and if damaged, which ones.
I can't tell from the video what the starter is doing, but it's easy to drop it and replace it. The bolts are 15mm.
Old Nov 27, 2006 | 02:05 PM
  #48
obZidian's Avatar
sure it is......... just remember when you first cranked her over and got into boost!!
I know how you feel, i think we all do. Money doesn't grow on trees unless your bill gates or some arab prince! We work hard, i know i do, to make these piles of crap run hard and honestly, without the misses not knowing exactly how much i have spent, i wouldn't change it for anything else... keeps me out of trouble!
Old Nov 27, 2006 | 05:27 PM
  #49
Got Me SOM's Avatar
pull the plugs and take pics and post em up here.
pour out some out some coolant post pics
drain oil look for chunks of metal and a gold sparkle stuff in the oil (bearings) take pics post em up.
should take you a 2 hrs to do all this stuff taking your time.
Old Nov 27, 2006 | 05:33 PM
  #50
RyanJ's Avatar
SSU Moderator
So, is/was all of this worth it? No less than 5 or 6 "what is wrong" posts since you had the car built, right? Honestly, is that power worth it?
Old Nov 27, 2006 | 09:11 PM
  #51
gator's 99TA's Avatar
that is a full low 8 second race motor/turbo combo you are driving around on the street. its high maintence for sure.
Old Nov 28, 2006 | 03:31 AM
  #52
Coy's Avatar
Coy
yeah it is.
Old Nov 28, 2006 | 07:22 AM
  #53
Old Geezer's Avatar
Question Tire spin..
at 130/4th gear???? Perhaps the "tire spinning" was actually the clutch slipping.. Clutch takes a $hit, and when your bud pushed it in, [at who knows what rpm], the disc parted company with the hub. This stuffed some $hit into the housing, locking the engine..Could also have knocked the $hit out of the starter?
You DO have a blow shield on it, right??
Old Nov 28, 2006 | 08:45 AM
  #54
V6 Bird's Avatar
Originally Posted by RW99
Any codes set?
This is the funniest post in this thread!
Old Nov 28, 2006 | 08:48 AM
  #55
V6 Bird's Avatar
The bolts are 13mm...Tell us how much you really work on your car hehe
Old Nov 28, 2006 | 08:50 AM
  #56
V6 Bird's Avatar
that was my thoughts on it exactly. I doubt it has a scattershield on it though.
Old Nov 28, 2006 | 09:18 AM
  #57
LS1Tech Co-Founder
13mm or 15mm I can't remember I'm getting old.
Old Nov 28, 2006 | 12:03 PM
  #58
So far this sounds the most probably. But I do assure you the tires were spinning at 120 as the back end of the car was walking left and right through the rpms.
Good news is, last night we drained the oil. Nothing in the oil, looked clean and smooth.
I have a switch on the car that kills ignition, so we had the car up on the jacks and i tried cranking it (without it actually starting) and there was a smaller noise coming from the bell housing, and when we crank it over it sounds like something is hitting in the same spot.
I was up till 3 last night so I didnt have the energy to start pulling the tranny and clutch but that should happen this week and I'll get pics posted of the damage.
Im assuming it must be the clutch since the only noise I heard came from the bell housing.
Edit: and no, no blow sheild, just normal bell housing.
Old Nov 28, 2006 | 12:06 PM
  #59
LS1Tech Co-Founder
Isn't there an inspection hole in the bellhousing, like 2" x 2" or something? Might be able to shine a flashlight up in there.
Old Nov 28, 2006 | 12:11 PM
  #60
we were poking around down there and I couldnt see how you can pull the bell housing back without pulling the tranny out first.
I could be wrong, but I wouldnt know where to look.
There was a small area where you can see to the flywheel without moving anything, but i guess it was too small to tell what was happening.
