2-Step Rev Limiter
Old Nov 27, 2006 | 03:12 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Default 2-Step Rev Limiter
Can anyone recommend a good 2-step rev limiter that will work with a LS1 based car? Specifically a 2000 C5.
TIA,
Keith
Old Nov 27, 2006 | 03:58 PM
JD_Z28's Avatar
TIA,
Keith
Synergy FTW.....
Old Nov 27, 2006 | 04:10 PM
jv_Z28's Avatar
TIA,
Keith
Synergy Motorsports (510)796-3749
Works great- I've used it.
Old Nov 27, 2006 | 04:52 PM
JD_Z28's Avatar
Hey we have a similar user name and we have the same turbo kit, Scary
Old Nov 27, 2006 | 05:09 PM
98turbls1's Avatar
John, you're soooo gay...And yes that is a good 2 step...
Old Nov 27, 2006 | 05:41 PM
JD_Z28's Avatar
Your SLOW atleast untill you get your car tunned.
Old Nov 27, 2006 | 05:44 PM
98turbls1's Avatar
Yeah, I'm slower now than when I didn't have the blower...Ehhh, I'm just trying to keep her safe though...
Old Nov 27, 2006 | 10:22 PM
Gauge's Avatar
11Second Club
Someone cure my ignorance. Explain exactly how a two-step rev limiter works. The basic idea is easy to figure out based on context but what are the details of how it works?
Old Nov 27, 2006 | 11:28 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
My understanding is that it cuts out half of the cylinders. If that is the case why doesn't it load up those cylinders and also foul out the plugs?
I have a 2step thru my BS3.
Old Nov 27, 2006 | 11:55 PM
98turbls1's Avatar
It's the same theory behind a regular rev limiter but at a lower rpm... Then when the switch is turned off the engine flashes to regular setting...
Old Nov 28, 2006 | 12:05 AM
SScam68's Avatar
I believe it's suppose to alternate between the fired and unfired cylinders.
Old Nov 28, 2006 | 07:57 AM
ls1290's Avatar
Anyone have any extra info on it? I did not see anything on their website.
Keith
Old Nov 28, 2006 | 11:19 AM
DanZ28's Avatar
It drops the spark to various cylinders, then on the next cycle, these plugs are fired again to prevent fuel from loading up in the cylinder to prevent backfires or roughness.
Old Nov 28, 2006 | 11:48 AM
ls1290's Avatar
How bad would that be on cats since non ignated air/fuel is being pushed out the exhaust ports? If the 2-step is set at 3200 RPMs, then half the cylinders are not firing......
Keith
Old Nov 28, 2006 | 12:03 PM
y2khawk's Avatar
it takes about 2 seconds at WOT on the 2 step at 5800 to send molten catalyst out the exhaust tips.
You should NEVER use one on anything with CATS still installed.
Old Nov 28, 2006 | 06:57 PM
SScam68's Avatar
Any news on the new 2step from ya?
Or mine for that matter
Frank
Old Nov 29, 2006 | 08:32 AM
Fire67's Avatar
Frank
Im looking forward to your new 2step as well. Been putting off the purchase of one hoping yours will be ready soon.
Old Nov 30, 2006 | 10:25 AM
ls1290's Avatar
Other than Synergy Motorsports, who else makes one? Synergy Motorsports does not respond to emails and it looks like Harlan is redeisgning theirs.
Keith
Old Nov 30, 2006 | 11:19 AM
DanZ28's Avatar
Give them a call, it gets pretty busy there. Their 2 step is a real nice piece and worth looking into.
Old Nov 30, 2006 | 11:32 AM
ls1290's Avatar
Anyone knwo the price tag of the Synergy Motorsports one?
Keith
