what cam should i use with my turbo set up?
i have two cams for my turbo set up but don't know what cam to use, I know there is alot of you out there that have tested some small cams and others with big cams so if any can give me any input and help me deside on what cam to use. here is a little run down of my set up
CAM MOTION 235/235 597/599 LSA 115
COMP CAMS 242/238 609/610 115+4
LME 370 CI. 8.5:1 CR
ETP 245 11* HEADS
VICTOR JR. INTAKE PORT MATCHED TO HEADS
NORIBILT CUSTOM UPPER HAT
90MM NW T/B
1.7 SHAFT MOUNTED ROCKERS
NORIBILT S88 TURBO KIT AIR TO WATER INTERCOOLER
ETP 245 11* HEADS
90MM NW T/B
Originally Posted by NA$TY-TA
Your kit close to being done yet???? Long time no hear about it man...
any Pic's??? I see you are going with the same turbo i have,,,,
Kyle
Kyle
Originally Posted by bud8fan
hey edgar get you a comp cam in the 228/230/580/580 /115 range...it works very well with boost in the mid and hi range w/ 346-370 ci....
I called a couple vendors to try and get an idea for cam specs, but they wouldn’t give me any information unless I paid for the cam upfront.
414ci, ported 317 heads, gt47-88 , victor Jr intake, static compression 8:1
i've analyzed Na$sty-TA's website alot to give me ideas and lead me in the right direction.
